I need the torque spec of the passenger engine mount, driver engine mount, and the lower engine mount please. I'm mid way through changing out my pulley and realized I don't have this info available. Thanks
Let us turn to page 110-26 in Bentley's please... Engine Mount Bracket to Transmission - 28ft/lb Engine Mount Bracket to Engine Mount - 50ft/lb Engine Mount to Body - 50ft/lb Lower Engine Vibration Damper to holder - 74ft/lb Lower Engine Vibration Damper to oil pan - 50ft/lb Top Engine Vibration Damper bracket to body - 74 ft/lb Top Engine Vibration Damper bracket to engine - 74 ft/lb
Thanks, buttoned up, went around the block and everything is good. Had a weird vibration at first but went back and re tightened a couple things around the belt tensioner and she runs like a champ.
