HELP with R53 S slave cylinder replacement/bleeding
Discussion in 'Starting Line - New Member Introductions' started by MKMotorist, Aug 9, 2014.
  1. MKMotorist
    MKMotorist New Member
    Aug 9, 2014
    Hello all,
    I followed agranger's directions on how to properly replace and bleed the clutch slave cylinder. I did both bleeding by using the power bleeder that I purchased under the direction of his article, AND did the 2 man bleed on the system before mounting it. STILL NO PRESSURE ON THE PEDAL! I don't know what else to do in order to solve this problem. I've looked at many other articles to try and find answers. Any ideas?
    Any help would be appreciated.
    Did you get fluid out of the bleed valve an how much?
  3. MKMotorist
    Aug 9, 2014
    Yes. I got fluid out of the bleed valve. I had someone press down on the pedal and bled it according to the instructions. So I took it into a shop and they said they got it working BUT now they're saying my clutch is going out. When I drove it last week the clutch itself felt fine so I don't know what's going on with it.
  4. Dave.0
    Yeah bleeding that slave is a B*@#H so I took mine to the Dealership and had them both done (Master and Slave) at the same time for $300 including parts. In and out in less the 2 hours. :Thumbsup:
    In my case "my time & no frustration" was worth the $300.
  5. MKMotorist
    Aug 9, 2014
    Reply to Dave
    Dave.0
    Did they just replace the slave cylinder and bleed both for $300?
    I just got my car back from the shop and they charged $150 to bleed the system and I still have no pressure in the pedal/it's hard to shift. The mechanic said my clutch is going out, but before replacing the slave cylinder, I had no issues with the clutch itself. He told me the pedal would self adjust after a few days. I call bull ****. So I'm just wondering if I need to replace the clutch master cylinder as well. I'm not sure if that's something I want to tackle on my own.
  6. Dave.0
    I had both changed (Master and Slave) and whole system bleed for $300 (Pats and Labor) at a MINI dealership.
  7. jasonsmf
    jasonsmf Active Member
    111
    27
    engineer
    Elyria, Ohio
    I find that this method works great for these situation:
    *Unbolt slave cylinder from transmission (leave fluid line connected)
    *Hold slave cylinder vertical (fluid line connection at the highest point)
    * DO NOT open bleeder
    *slowly push piston fully compressed
    *let piston extend fully on it's own
    repeat the compressing/extending the piston a few times. This will fill the slave with fluid and force the air up thru the line and out the reservoir. Just be sure to leave a little extra space in the reservoir so that the fluid doesn't overflow when you push the piston fully compressed.
    This method has never failed me.
  8. agranger
    Yea! I'm glad to see that the instructions are providing some use to folks!
    Yes... this process is A *****! I swear that I'd do it 10 times in a row, the exact same way every time, with 9 failures then, all of a sudden, BAM! It works. I usually had to do both methods... I seemed to get a good result with the 2-man STOMP method (the more violent the clutch press, the better) to get 95% of the way there, then the pressure bleeder to get the last 5%.
    Just keep at it. At some moment of extreme frustration, the clutch fairy will look down upon you and say 'enough', and it will work.
    Aaron
