So as I was driving today the indicator came on with the car up on a lift as well ad the brake indicator. In the book it says "Vehicle Electronics Failed" "You cannot continue your journey" everything still seems to be working just fine so just wondering if anyone has suggestions on what I should do about it?
That's what I thought at first but then I looked at the code thing in the book and it said something bout the electrical...brakes still work fine but Ima get down and check em out just to be sure.
Tried doing that. Couldn't figure it out. Went to Autozone and there are no code readings so that's all good. One of the rear brake pads looks like it could be thin enough to set it off. I will most likely be changing them this weekend.
