Hesitation/low power when taking off from stop light
Discussion in '2nd Generation: 2007+ R55 through R61' started by Dr_N, May 30, 2023.
  1. Dr_N
    Dr_N New Member
    May 1, 2022
    6
    Hey all,
    2013 r56 (non S) with 57k miles. Owned it a year with no issues other than replacing ignition coils. Lately it has developed an issue with hesitation and low power when taking off from a stop. It really only seems to be an issue through mid rpms in first gear. Any thoughts?
    Sent from my SM-S916U using Tapatalk
  2. 00Mini
    Welcome to Motoring Alliance. Not being much of a mechanic I’d check for any engine codes, then check the spark plugs and vacuum leaks.
  3. MCS02
    Not really sure but if you know your coils and plugs are good it could be a fuel pump or filter problem
  4. Dr_N
    Dr_N New Member
    May 1, 2022
    6
    Thanks, I know the coils are good, but haven't checked plugs yet. No codes since the could were replaced. I'll look at plugs and vacuum leaks when I get home.
    Just spit balling here, maybe the HP fuel pump on its way out?
  6. DneprDave
    Dirty air filter?
  7. Dr_N
    Dr_N New Member
    May 1, 2022
    6
    Is there a way to test the fuel pump?
  8. Dr_N
    Dr_N New Member
    May 1, 2022
    6
    Changed the air filter when I did the coils recently
  9. MCS02
    You could with a fuel presser gage but I can’t remember if the R56 has a place to attach a gage. Maybe some of our R56 guys will know. If not I can look at my wife’s Mini when I get home this afternoon. Have you changed the fuel filter?
    I'm a bit embarrassed. I thought you had a Cooper S. The regular non turbo Cooper is not a direct injection engine so no HP fuel pump. If you don't have one you should pick up a copy of the Bentley shop manual for the R56.
  11. 00Mini
  12. Dr_N
    Dr_N New Member
    May 1, 2022
    6
    No worries, I'll check it the Bentley manual
  13. Dr_N
    Dr_N New Member
    May 1, 2022
    6
