Hi my name is kevin , I have got a starting intermitted problem with my 2003 Mini Cooper Battery new All lights come on the dash I here e relays working when I turn the key But the car won't crank up Had a dyonostics on and found no problems Hope some guy has had the same fault and found the cure of it
Welcome to M/A. Check all battery & cable connections. Start with the easy stuff first. How old is the battery?
+1 on the battery. MINI's don't like old batteries and throw all kinds of electrical gremlins when they start to go bad. Also check the jump start stud in the little black box on the left side of the firewall under the bonnet. These have been known to come loose and/or corrode which causes problems similar to what you explained.
The new battery posts may be a smaller dia. than the old one and when the clamps are tight they are still loose on the post, ask me how I know....
Hi tried clutch switch that's fine Put new starter motor on today still nothing ????. ALL EARTH CABLES CLEANED and tight Got me beat now think am going to have to take to BMW garage.
