1. MGBILL1186
    MGBILL1186 New Member
    Apr 26, 2015
    13
    Hello brothers and sisters of the Mini lovers camp.
    I'm expecting to take possession my new Mini in the in the first week of June, and have been surfing web sites regarding upper and lower strut tower braces. I know the F56 is new, but are there any braces currently out there that you recommend. I've looked at the OMP strut brace and really like its design but alas it's not made for my model. I really value this websites members opinions and look forward to meeting all of you down the road!
    I moved this to it's own thread in order for it to be noticed.
  3. wmwny
    4,048
    2,246
    Welcome to M/A!
    Oh, and it may be a bit a bit early in the F56 life for the aftermarket companies to get things going. With that in mind I'd check some of the M/A sponsors and ask them what they have or have heard about availability of F56 parts.
  5. Zapski
  6. MGBILL1186
    Apr 26, 2015
    13
    Thanks for the info Zapsky. You've helped already, and I purchased an "S" model. I'm curious as to your thoughts on replacing the stock rear sway bar with an after market 22mm sway bar. There's little chance of a track day here in St. Louis but I do like the twisties in the area. If I would get the sway bar I would also get the adjustable link pins. Your thoughts sir! Thanks for your help.
  7. MCS02
    Welcome to MA! congrats on the new Mini!
  8. Dave.0
    Welcome to M\A the FUN MINI site! :Thumbsup:
  9. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
  10. Metalman
    Hello and welcome...
    Congratulations on the new MINI....
  11. Savvy
    You don't need the adjustable end links. Unless you drop the ride height with an aftermarket suspension... then I'd get them. The rear sway bar is nothing more than a giant torsion spring tying the rear wheels together (and to the body). It will change the handling dynamics of the car. So, if you have already found limits on your favorite roads. Know those limits are likely to have changed once you install a bigger/stiffer RSB... and be sure to relearn the new limits so you don't do something horrific.
  12. mrntd
    Welcome Aboard!
  13. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Welcome to the coolest MINI forum on the net.............:cool:
  14. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Welcome! I might hold off on strut tower braces: on MINIs, they don't make much of a difference because the strut mounts are so close to the front bulkhead, so they're really stiff already. Look around this site to see some of the more popular mods.
  15. 00Mini
    2,227
    Enjoy your new ride and Welcome to Motoring Alliance the onlyest MINI Forum you'll ever need !!
  16. MGBILL1186
    Apr 26, 2015
    13
    Good Info
    Thanks for all the good and wise advice. My association with this forum is paying off already. Good advice from my new friends! Many thanks......
