High Oil Use not Limited to MINI
Discussion in 'Other Vehicles' started by Nathan, Jul 1, 2013.
    Found this article by the editors of Consumer Reports stating that high oil use in new cars is the new norm.
    Full article - Consumer Reports sees oil vanish from some test cars
  2. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I wonder if manufactures are designing engines a little looser, especially in the piston/cylinder contact area to reduce friction and improve gas mileage figures. In general the manufacture does not care that the consumer has to add oil and the consumer only sees fuel mileage numbers, not oil consumption, when purchasing a new car.
    Maybe the oil God's are punishing those who drive Panameras? Could it be that direct injection plays a part? Maybe the manufacturer's have come up with cars that self oil change?
    Yes that is a high usage rate & that is troubling, but what is even more troubling is that very many owners never lift their hood & pull a dipstick. Not even the automotive experts at Consumer Reports.
  4. Metalman
    Nope...
    It's because they consolidated their engine ears....
    Bunch of 2 cycle engine ears are running the show now....:D
  5. MCS02
    6,278
    Maybe it's the thin oils they use. 0w-20? Man is H2O next?
  6. Jason Montague
    :popcorn::popcorn::popcorn:
  7. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    #7 Apok, Jul 1, 2013
    It was explained to me with the VW 1.8T that I had in my Audi TT Quattro that the cylinder walls were designed to be microscopically porous in order to make the oil sick and be consumed and burn off some of the oil for some purpose that that I have suddenly forgotten while typing this out. So carry on. :postcount
  8. RussWK
    RussWK Active Member
    Apr 1, 2011
    106
    61
    Oil Usage
    Interesting. In the old days cars used a quart every couple thousand miles. Now my 2006 MCS stays at the same oil level until changed - 9,000 miles or so, with 0-W30. Any oil usage is imperceptible. Are we going back to the old days? Maybe the first Gen is still the best bullet-proof engine ever used in a Mini. I understand it is a Neon motor made for European market.
    --Russ
  9. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    I just installed my AEM intake system on my 2007 MCS, when I unclipped the PCV hose from the turbos inlet there was plenty of oil leaking out. Why on earth would manufactures design a PCV system that burns large amounts of oil? What's in it for them, money from oil companies in these bad economic times?
  10. Jason Montague
    :cornut: An OCC would keep that out of your intake and used in conjunction with a BSH dual tap, all of the crank case blow by would be kept out of you intake system.:Thumbsup:
  11. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    This is a common trait in pre-LCI Prince engines, and was onerous enough to warrant the design change that occurred with the 2011 model year.
    I've owned three MINIs ('05 N12, '11 N18, and '13 N16) and have never had to add a drop of oil between ~5K mile oil changes in any of them. No perceptible oil consumption. Just lucky I guess.
  12. Systemlord
    Mar 28, 2013
    311
    67
    Will the BSH dual tap and BSH Mini Cooper R56 Competition Catch Can effect my 6-year/120,000 mile warranty? Also will my local Irvine CA Mini/BMW dealer have a problem with these components?
    Appreciate it!
  13. Dave.0
    I use a lot of oil because I change it every 3k because I also run Meth.
  14. Jason Montague
    #14 Jason Montague, Jul 6, 2013
    :cornut: MINI of Dallas thought that my OCC and Dual Boost Tap were a good solution to the carbon problem and never had any problems with this mod warranty wise.:Thumbsup:
    I just realized that you're in California. So with that in mind, I don't know what the CA Air Gestapo would think about this. Before you buy, ask the OCC dealer whether it's CA approved.
    I would ask the folks at the dealer that services your MINI. Most would not have an issue with those mods. They are not for power, but for longevity of your engine.
  16. CamtheWookie
    CamtheWookie New Member
    May 17, 2009
    131
    32
    Huntersville, NC
    My '05 MCS never really burned a measurable amount of oil, and I was on a 4-5k interval for changes as well. :confused5: I suppose I must have been lucky as well. Curious to see how my CM JCW does when it gets here.
  17. fngolfer
    fngolfer Active Member
    Apr 1, 2012
    100
    46
    Los Angeles
    Oil usage
    2009 R56 manual with 44,000 miles. BSH oil catch can driven 50 miles daily and vitually no oil usage. When I drain the can, it's 95 percent condensation. A bit more oil in winter months. I change my oil every 5000 miles.
  18. Jason Montague
    :cornut: Me Too! 08 R56 BRG MCS/JCWm :Thumbsup:
  19. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    My 08 MCS burns virtually no oil between changes.... But I only have 33K miles on the clock.
  20. minirab
    My 06 R53 used no oil at all between changes, sold it with 75k on the
    clock. So far my 2012 R58 JCW with 14k has not used a drop either.
