1st Gen R53 Cooper S High output Alternator
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Sleek Motoring, Feb 9, 2015.
  1. Sleek Motoring
    Sleek Motoring Local Shop Owner
    Dec 7, 2014
    249
    143
    Mini repair shop owner
    Colorado Springs, Colorado
    I currently have my engine out of the car, I would like to go to a higher output Alternator. I am thinking about having it rebuilt instead of going with a whole new unit.I already upgraded to a odyssey battery and I've seen a few new alt on the net (not sure of the build quality)
    A few questions:
    -Does anyone have a recommendation for a shop that can rebuild them?
    -Options for a brand new high quality high output unit if I choose not to rebuild.
    -Will I need to upgrade the battery cable gauge size running to the trunk and add an inline fuse?
    -Upgrading the ground AWG size? Adding more grounds necessary?
  2. Kenny kustom
    Kenny kustom New Member
    Jan 24, 2015
    297
    178
    I've had some ho alternators before.
    Try Ohio generator.
    Usually best you will get is maybe 20A more.
    Unless you could massage a larger frame in there.
    No need to upgrade the wiring. Why do you need a larger alternator?
  3. Dave.0
    Why do you think you need one?
    The OEM one works fine unless you are somehow stuffing 10,000 watts worth of old amps and 20 Subwoofers.
  4. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    This is kind of what I was thinking. If an HO alternator is the answer, what is the question?
  5. Metalman
  6. Sleek Motoring
    Dec 7, 2014
    249
    143
    I will be adding a few more lights, a JL amp, HFS-3 Aquamist system (pump runs constantly),uprated electric cooling fans,uprated fuel pump,and the big one is an AccuAir air ride suspension system. That system constantly adjusts while driving to keep the car level.
    With all that I thought it would be beneficial to upgrade the ALT output to reduce the strain on the stock system (or am I overthinking this).
    I've had noticeable improvement when i've upgraded grounds and charging cables coming off the alternator on these newer cars with multitudes of sensors sending information to the ECU.
  7. Dave.0
    I think you are over thinking it because I have a JL amp (900w) and a Aquamist meth system and have no power issues.
    The Aquamist pump does not run all the time. It only runs when it's triggered based on the duty cycle on the injectors which you set yourself. My Aquamist kit is on all the time but the pump does not always run.
  8. Kenny kustom
    Jan 24, 2015
    297
    178
    You might be better served by running dual batteries. Maybe a pair of 925 Odyssey.
  9. Sleek Motoring
    Dec 7, 2014
    249
    143
    I would rather not have that extra weight of another battery. I guess all I am asking is if I upgrade the amperage of the alternator am I going to have to upgrade the gauge wire going to the battery as well?
  10. Kenny kustom
    Jan 24, 2015
    297
    178
    Lights, stereo, air tank, compressor, etc.
    And you're worried about the weight of another battery.... Lol.
    Your answer. Maybe.
    Depends on the amount of charging upgrade.
  11. Kenny kustom
    Jan 24, 2015
    297
    178
    Why not contact Ohio generator as I suggested. Ask them about the possibility of upgrading your alternator. Once you have some amperage specs. Then you can go from there.
  12. Canusrufis
    Canusrufis RMW Powered R53
    210
    107
    Winston Salem NC
    http://www.qualitypowerauto.com/Wire%20Sizing%20Chart%2012V%20DC.htm
    wire gauge chart. You would need to figure total amps -- I'm guessing your north of 200A. Back in my electric motor days whenever we needed slightly more Amperage a smaller alternator pulley was used. Here that would be especially useful at idle when the alternator pulley spins slower, thus producing less useful current.
  13. Metalman
    At 200A the chart calls for 4 gauge.... Pretty sure the stock isn't that heavy...
  14. TheModFather
    Actually it is! From the alt to the jumper post and all the way to the back for the battery... ;)
  15. Metalman
    I forgot the 1 gen has the battery in the back.... So that would be a 1 gauge, so that would make the wire .289" diameter for a 200A...
  16. Dave.0
    This is still the best answer. :eek6:
    Weight concern......where.....:ihih:
  17. Sleek Motoring
    Dec 7, 2014
    249
    143
    Those other parts add more functionality to the car (yes, and weight) Not just adding to the electrical system!
  18. Kenny kustom
    Jan 24, 2015
    297
    178
    Just remove the alternator and take it to any rebuilder. They should be able to give you maybe 25 amps more.
    Find the largest battery you can fit in the trunk. Done.
  19. Sleek Motoring
    Dec 7, 2014
    249
    143
    Thanks!
    I am going to send it to Generator Exchange in Denver. I am going to get a mild upgrade to Amperage.
    I have a really nice Odyssey battery going in!
  20. ZippyNH
    If you are running a big intermintant load, you might want to consider getting a "batt cap", aka a capictior, added inline to the heavy load...were once used with high load amps before they became more efficient. In a radio install, it provided the extra surge power to prevent the lights from dimming from heavy bass....might be useful in your install if you have concerns of the need for sudden surge current being needed, like the air compressor (most decent installers actually install one on home ac units, same idea, prevents the house lights from dimming, etc when it kicks on).
