Brakes Wheels 2nd Gen Tires High Perf All Season Tires
Discussion in '2nd Generation: 2007+ R55 through R61' started by TGS91, Aug 30, 2010.
  1. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Guys,
    I have kind a rub here in St. Louie. I get enough ice and snow that I can't go Summer tires and I don't get enough snow and ice to justify a set of snow tires.
    I've been going All Season High Performance for the last two sets. Theres a trade off to be sure but it makes sense for where I'm at geographically.
    Heres what I've used so far
    Nitto NeoGen's - Very good, very sticky, bad part lasted about 15K
    General UHP Exclaims - (current) Higher rated UTOQ but leave allot to be desired in the twisties (tire roll and ALOT of squealing)
    Considering-
    Bridgestone Potenza RE960AS Pole Position
    Continental ExtremeContact DWS (top rated on TireRack)
    Hankook Ventus V4 ES H105
    Yokohama ADVAN S.4
    'Nother set of Nitto's
    I'm a very aggressive driver, I think the term is 'Twisty Addict' and want to use them for at least a couple track days.
    Any experience with these? (please include your driving style)
  2. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    Ive heard tons af good about the Potenza G019 Grids... Probably will be my next tire.
    Looks just like the 960.... Are they basically one in the same??? lol
  3. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    I believe the Grid 19 and 960's are very similar but the 960's a bit grippier and the 19's conversely a bit more durable
  4. Minidave
    I'll throw another name into the hat - Kumho Ecsta ASX.
    We pretty much get the same weather as you do, I've had a couple sets of these on my MINIs and get right at 30K out of them. The other thing I really like is how quiet they are, even when worn down to the wearbars. They do well in everything but deep snow, where they're just OK - but they got me everywhere I needed to go, even so.
    Only $94 each too......
  5. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    What would you characterize your driving style?
  6. BThayer23
    I have B'stone Grid 019's on my other car, an E36 BMW and they're great. Comfortable ride, quiet, and sticky enough. They're nothing like the Dunlop Star Specs on my MINI, but they're solid when I throw them into a corner.
    I wouldn't recommend taking all-season tires to the track, though. You'll cut 5,000 miles off the tire in one weekend. The small, tall tread blocks on all-seasons heat up unevenly and chunk off. When you put that kind of tire into a turn, the tread blocks lean over before the tire does, creating a lot of stress and heat at the bottom of the block. They heat up and fall off as the rubber gets overstressed. My all-seasons start squealing way before my summer tires do - I can hear the tire's unhappiness. If at all possible, pick up a set of somebody's takeoffs and run whatever tire they have on there, especially if they're down below 4/32nds of an inch (2/ or 3/32 is ideal).
    A Swiss Army knife is a knife, but you'd never use it at your dinner table to cut steak. You'll be much happier using the right tool for the job. And I don't mean to single you out, Tim, I just hear this line of thinking a lot.
  7. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Nothing personal taken and I think your spot on
    What you describe occurring to All Season tires on track days is exactly what happened to the General UHP's
    Maybe the solution is Summer High Perf for spring/summer/fall/track days and All Season tires for Winter here in St. Louie. Something to ponder
  8. Minidave
    What BThayer is saying is correct - depending on just how agressive you want to get at the track.
    I'm not trying to set TTOD, so I have yet to damage my Kumhos, this in no way means I'm a slow driver - I'm not. I guess I'm more of a Jensen Button than a Sebastian Vettel when it comes to tire wear. :D
    Tread design has a lot to do with it too. The Kumhos have a different tread than other UHP all seasons - I'm not suggesting they're as good as a summer tires, but they certainly don't chunk off under hard use. They're also very progessive and give fair warning before they slide - when they do slide it's not an abrupt all or nothing deal either - very forgiving. Oh, and they're "Ultra" High Perfomance - like they go up to eleven instead of ten! :D
    As to my style, I don't speed on the road, and here in Kansas twisty really isn't in the vocabulary - straight and grid-like figure heavily, but curves? Not so much. However I do partake in the "onramp grand prix" whenever possible, and I do about 6 track days a year - rain permitting. This year I'm 0-4 so far, with another one scheduled for this Wed and t-storms threatening again to cancel the event yet again!
    I'll have my vid cam in for Wed's track day, that should give you an idea of my style and the amount of tire squeal I produce (very little actually) like I said, I'm more out of the JB school of "smooth and boring but fast and easy on the tires" type of driver.
  9. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    I think I'm a Sebastian with Jenson aspirations :lol:
  10. ftttupwmcs
    ftttupwmcs New Member
    May 17, 2010
    39
    I just got two Conti Extreme Contact DWS in 215/45 ZR 17 for the front due to having to replace one Dunlop runflat. I will eventually get the other two when I can. I love these tires! $329.00 out the door. I've never been on a track but I like going on MINI runs when I can. The more aggressive, the better.
  11. BThayer23
    We had a DWS "club" going on the local forum. Consensus seems to be great wet and snowy tire, smooth quiet ride, but at the expense of grip. Price is great for an all-season, though.
  12. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Ben (at least I think thats your name) or Bthayer
    Thanks for clarifying my thoughts
    Think I'll ride the General's through the winter as that's what they are good for
    In Spring get me some grippy ultra high perf summer tires and if the General's have anything left save them for the Fall/Winter of 2011. If not get some sort of All Season/Winter tire at that time
  13. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Another thing
    I found is that when I went from stock front camber to -2 degrees, I doubled my tire life with all types of tires. I now get mid 20ks from the tires I run, including track days. With stock camber, one weekend would really eat up the outside fronts, and two weekends could kill a set. My driving has gotten better so it's not as bad as it was, but if you haven't gone to more agressive camber, you may find that a set of plates will pay for themselves in one or two sets of tires.
    Matt
  14. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Yet another area that is coming up on my "what to do to the MINI to make it better/faster"
    Did not realize the tire wear savings, thought it was mostly a handling improvement. What your saying makes sense though and the more I think about it the two are intertwined
    Dr. O strikes again!
  15. BThayer23
    Sounds like a plan. :Thumbsup:
    And yeah, it's Ben.
  16. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    If you drive hard in twisties
    then some camber help up front is a must for tire life. The "extras" you get with it are better front/rear balance (it reduces understeer) and higher grip levels before the car slides because of improved contact patch management. Sell it to the wife/girlfriend as a safety upgrade!
    Matt
  17. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Then I'll have to get it for her MINI! :D
    She gets the 'go fast' budget
    I just bought her replacement appliances for the kitchen so she should be somewhat softened up
  18. Squirlz
    Squirlz New Member
    General UHP Exclaim is a Summer tire, not an all-season.
  19. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
  20. Squirlz
    Squirlz New Member
