1st Gen R53 Cooper S Hood problem ...
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Devrider, Feb 12, 2013.
  1. Devrider
    Devrider New Member
    Jan 10, 2013
    37
    Industrial designer
    Montreal, Quebec, Canada
    I have a little problem ... one of my cable hood brake, so i'm not able to open my hood ... I live in the north and need to fill my windshield washer tank ... It only "pop" on the passenger side ...
    Is it possible to "pop" the other side from under the car ? If not what my other option
    DEv
  2. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Take off your right wheel, then unscrew all of the plastic screws that fasten the wheel well cover in place. You will be able to reach the mechanism and reattach the cable.
  3. Metalman
    Some people add a cable tie to the receiver that contains the cable end.... This DIY prevents the cable from detaching from the lock mechanism in the future....
    Look for the small black plastic cable tie in the picture...
    Simple worthwhile mod...:Thumbsup:
  4. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Thanks for added that MM! I forgot about that mod.
  5. Devrider
    Devrider New Member
    Jan 10, 2013
    37
    Industrial designer
    Thanks guyz, i'm happy to see thati'm not the only one
    DEv
  6. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Keep us posted if you fix it.
  7. Devrider
    Devrider New Member
    Jan 10, 2013
    37
    Industrial designer
    I'll try to fix it this weekend ... I have no place to work except in the father's garage ...
    DEv
  8. Devrider
    Devrider New Member
    Jan 10, 2013
    37
    Industrial designer
    Problem fixed ... Very easy to reach it when wheel plastic are out ... I'd get to check my foglight in the way ... And remove my broken glove compartment ( need to find one ... )
    DEv
  9. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    Thanks for this tip! I am learning so much from all the tips that are shared here! I just did mine.
  10. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    That engine bay sure looks clean. :cool:
