I'd like to make a minor update to my garage, but I can't find the edit button. It's probably something simple that I'm overlooking.
Access the Garage nav bar item in the header. Select My Garage in the drop down. From there you can add or edit the Garage. Note: this is from memory and not actually tested as I'm in Tapatalk right now and pretty darn drugged up
You just type in what you want in each category then click save changes at the bottom of the screen. You have full edit control on everything in you User CP section. Nathan is probably busy watching his scar heal so he won't get on this right away. Well!! There he is before I could hit save.
