1st Gen R53 Cooper S How do I know if my suspension is bad?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by tskorka, Dec 16, 2011.
  1. tskorka
    tskorka New Member
    Dec 16, 2011
    10
    I recently bought a 2002 Cooper S. I know the ride is supposed to be firm but there doesn't seems to be much if any damping. I switched the 17" runflats to 16" steel rims for winter but still seems stiff. Going over bumps I don't notice any rebound. What DIY stuff can i do to check for bad struts or springs?
  2. CHKMINI
    Is the car lowered or at factory stance? Does the car have coilovers?
  3. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    #3 k-huevo, Dec 16, 2011
    Stock springs are very well made and their service long lived. Spring height could be measured against a spring from another MINI for a ball park reference, but a completely sacked stock spring is less likely than worn shocks. They could be spring dyno tested, but that's no longer DIY.
    For the shocks, first visually inspect for leaking fluid.
    Remove the struts and disassemble, screw the shock shaft nut on the end of the shaft to protect the threads, invert the shock on a non marring surface (like wood), press the shock body downward to push the shaft inward, raise the shock. The shaft should extend slowly, taking about 12 seconds to return. If the shaft does not return, and/or it makes excessive gurgling noise, it is time for replacement. If you can compress and return the shaft with only arm strength (think playing an accordion, plus sounds like a washing machine), time to replace the shocks.
  4. tskorka
    tskorka New Member
    Dec 16, 2011
    10
    I believe it is stock sport suspension. I will jack up the car this weekend. If it is the shocks and not the springs what is a recommended replacement? Is Bilstein Touring ok for daily driver usage? Thanks!
  5. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    It wears leather jackets and smokes and hangs out with the wrong crowd? :D
  6. k-huevo
    159
    Pipe Creek, Texas
    Bilstein Touring shocks are ideal for daily driven street use. If you decide to install them, post again and I'll provide some tips. The touring model front shock body is a fraction of a millimeter larger in diameter than stock, and has a square bottom edge that keeps it from inserting easily within the steering knuckle.
    Be sure to check the type of attachment for the front stabilizer bar link. Enter your VIN# here RealOEM.com * Online BMW Parts Catalog to see the differences. If your build date is prior to April 2002, more parts will be needed to make it work.
  7. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    KHuevo, is it possible for shocks to go bad without leaking any fluid? That is, if you don't see any fluid leaking out, can they still be bad? I am going to guess that the internals can go bad without external leaking, but please confirm. Thanks!
    (I am not sure exactly how shocks work but isn't there some restricted transfer of fluid from one chamber to another which provides the dampening effect?)
  8. k-huevo
    159
    Pipe Creek, Texas
    #8 k-huevo, Dec 16, 2011
    Yes, damping can deteriorate without fluid showing outside the shock body. In the absence of a visual cue like a leak, aural as in knocking (FSD does this when failed), or physical like the car bouncing five times for every bump, it's time for a hands-on test.
    There is a lot of information about how shocks work available on the web, Bilstein has a good video to look for. As you suspect, there are restrictions called valves (orifices, discs, flappers/gates, etc.) that meter the flow of fluid from one chamber to another providing a damping effect.
    It may be possible what the OP interprets as shock failure, is just a characteristic of the early model shock. Early models were filled with a heavy fluid, which provided a steep damping curve and less-than-cushy ride. Cold temps don't allow the shock to warm sufficiently for faster fluid flow; combine the two and bumps can become jarring.
    An addendum for the hands-on test, if the shock shaft will not move without extreme effort, that's a test fail too.:)
  9. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    Thanks. Good to know.
  10. tskorka
    tskorka New Member
    Dec 16, 2011
    10
    I ordered a suspension kit from Pelican Parts that includes the Bilstein Touring struts/shocks front and rear. Waiting for all the parts to arrive...
  11. tskorka
    tskorka New Member
    Dec 16, 2011
    10
    I havent jacked up the car yet but is pushing on the front/rear bumper an ok test? There is no movement in the rear and only a little in front. How much movement should I see?
  12. jiminni
    jiminni Well-Known Member
    262
    Ca.
    You never said how many miles are on it? With a Mini that age I would bet that all your front bushings are shot, and more than likely the motor mounts are too.
    I had the nice folks from Helix change out my control arm bushings at the dragon this year. At 95,000 they were nothing but dust. As far as how my car rode it really did not make much of a ride difference. It made a heck of a lot of difference as far as turn in went. Over time I had not realized how loose the steering had gotten.
    I'm still on the oem shocks at 101,000 & am getting ready to swap in another set of low mileage oem's I have.
  14. tskorka
    tskorka New Member
    Dec 16, 2011
    10
    There are only 57,000 miles on my 02 mcs. The only problem I notice is it is sooooo harsh going over bumps. At first i thought this was how it was supposed to handle, but my friend said that my shocks are shot.
    Wishing i had taken it to a mini expert before buying!!
    Going to take it to a friend with a lift to inspect the suspension. I plan to do all the work myself. I'll give an update when I know more.
  15. Nathan
    Does the MINI still have runflats for tires? If so that can be a large part of the harshness. The early cars were not designed with runflats in mind. This can lead to a very harsh ride.
  16. tskorka
    tskorka New Member
    Dec 16, 2011
    10
    I did swap out the runflats for winter tires on steel rims. It's a slight improvement but when I go over say a decent sized hump in the road the whole back end seems to fly in the air!
  17. RayanMX
    RayanMX New Member
    Mar 8, 2011
    Mine's same age and about the same mileage.
    It's got more or less the same suspension behaviour, and I'm running 17" non runflats.
    But in my case my MCS has a factory sports suspension which as far as I have read, its lower than non sport and a bit harder too. (Am I right?)
    The only work I've done so far (knock on wood) is change both upper tower (strut bases), two front wheel hub bearings, and fixed a bit of mushrooming on both tower bases.
    I still have a problem with a bit of suspension thumping when riding on rough pavement (suspect a damaged bushing somewhere) and also a bit of loose steering too. Specially when turning left while accelerating or even worse while releasing the gas pedal.
    Happy new year by the way!
  18. Jason Montague
    :cornut: I don't know about R53s but, MINI says that my R56 MCS/JCW with factory 'Sport Suspension'(not JCW Suspension) is 8mm lower (1/3in) than standard suspension. Plug 'Sport Suspension' into search above and you'll get a lot more facts on 'Sport Suspension.':Thumbsup:
  19. RayanMX
    RayanMX New Member
    Mar 8, 2011
    Thanks for the heads up Jason!
    :Thumbsup:
  20. tskorka
    tskorka New Member
    Dec 16, 2011
    10
    Well my new struts are installed. All new Bilstein Touring struts! Turns out only the back ones were shot. My friend and i did the work ourselves but after install there was a clunking noise going over bumps. I took it to my mechanic and turns out the strut nuts were not tight enough. He used an impact wrench to tighten all 4 nuts. The mechanic also did an alignment. The ride is so much better now!
