How do you reset tire warning on R53?
Discussion in 'Wheels & Tires' started by goaljnky, Feb 15, 2011.
  1. goaljnky
    3,105
    394
    I swear. Every two years I get a nail in my tire, the light goes off and I never remember how to reset it. Someone help a brother out?:confused5:
  2. cct1
    It goes off every time I switch tires for the track. Hold it down when you start the car for five seconds, then drive, it resets after you drive. At least that's how mine does.
  3. Zeyk_Shade
    Zeyk_Shade Member
    Oct 14, 2010
    89
    ^^this.
  4. wmwny
    4,040
    2,242
    I hit the reset button that's down by the emergency brake. Then I shut off the engine, restart it and hit the reset button again. The light usually goes off after the engine is restarted, although you may have to go thru the sequence a second time.
  5. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    Mine did it recently and from what I remember I had to hold the button down for a bit before it went off.
  6. ScottinBend
    as would be said on the "other" site.....
    RTM ! ! ! (or maybe RTFM)
  7. goaljnky
    3,105
    394
    I did. The damn thing says something completely different. But it's reset now. Though I have no frigging idea what I did. :D
  8. ScottinBend
  9. Minidave
    According to the manual in my '03, it said to do exactly what cct1 wrote.
    Hold the button down for about 5 sec, then drive - the system will re-learn the new pressures (actually, it's learning the diameter since it works off of the ABS sensors) and off you go....
  10. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
  11. goaljnky
    3,105
    394
  12. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    #12 Friskie, Feb 17, 2011
    I just now got my bothersome lights to go out. The ABS, ASC and tire light wouldn't leave me alone for the last three days. Whenever the brakes were used it felt like someone was pouring a hand full of gravel into the system. Following everybodys best guess on this thread, pulling each wheel off and checking for junk stuck to something it shouldn't be, the lights are finally quiet and a drive around the block feels like it's old self. Thanks for all the input.:Thumbsup:
    4 some hours later and it's doing it again. The brakes chatter when coming to a full stop and all the lights go on. Run in to pay a bill, come back out, turn on the key and everything is fine 'till the next red light.:mad5:
  13. ScottinBend
    Wheelspeed sensor is going bad.
  14. Friskie
    Jul 20, 2009
    1,650
    1,333
    Well, it uses a dipstick, therefore...
    Thanks for the input. I'll persue that idea.
  15. Commander Dan
    Commander Dan New Member
    May 13, 2009
    82
    6
    Medical Equipment Service
    Alpharetta, GA
    Well thanks to goaljinky, I finally got my tire pressure warning light to go out! I had a slow leak repaired yesterday, then went through the 5 second deal, and BINGO! The light went out! (Just in case it matters, I've got a 1st Gen. ['07 Cabrio] vehicle.) Thanks!
  16. MiniHockey
    MiniHockey New Member
    Oct 20, 2010
    109
    my light came on and i checked the tires and all are at the right air pressure? now what?
  17. Crashton
    Reset the light. The instuctions are in post #2 in this thread.
    For some odd reason those tire nanny's seem to come on once in a while for no apparent reason.
