How I Clean Wheels
Discussion in 'Detailing' started by Batrugger, Jun 17, 2011.
  1. Batrugger
    Batrugger New Member
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    I bought a beat up set of BBS RZ's from an old Corrado to put on my Scirocco a couple of years ago. We have an old BBS wheel guru who owns a wheel repair shop close by and I went to him to see about getting them refurbished. He told me that he wanted me to clean them up first and that the best way to do it would be to soak them down with WD40, let them sit overnight, and then clean them up with soap and water. I was a little skeptical, but he assured me that the WD40 was safe and would not damage anything and that he had been doing it for years. I did as he said and the results were amazing. The wheels on the Rocco hadn't been washed in months and were looking pretty bad, so I decided to clean them up and show you the result using the WD40. Here is one after being sprayed and soaking overnight:
    To clean wheels thoroughly, I like to use a microfiber car wax applicator with regular car wash soap and water. The great thing about the WD40 is the crusty brake dust will just wipe off. Here is the same wheel after the wash:
    Too easy and it looks great.
    Simply brilliant!!!
    I'll have to remember that WD40 trick. Sweet..... :D
  3. Onramp
    Onramp Enjoy the Hiways of Life!
    Retired, mostly
    Renton, WA
    Dang! I'm gonna try that on my track wheels.
    Pat
  4. TATTRAT
    TATTRAT Well-Known Member
    496
    399
    Executive Chef
    NoVA/DC
    makes sense. WD is for water displacement, so it will penetrate and cling to dirt, and hose off as oil and water don't mix.
  5. Justa Jim
    Cool. Will it hurt painted wheels?
  6. CHKMINI
    So...can we now say that WD40 stands for Wheel Detail 40?????
  7. MI MINI S
    MI MINI S New Member
    Apr 21, 2010
    16
    Wow I am going to have to try this trick. Thanks for the tip!
  8. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Wow they look great! When you say 'soaking overnight' are you referring to simply spraying and leaving it on the rims or are you referring to some liberal amount of WD40 in some sort of bucket with the rim face down in it overnight?
  9. Batrugger
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    No the wheels shown are painted OEM BBS silver and I even spray it on the yellow powder coated brakes to clean them up. The wheel guru even claimed that it pulled the metal flake in the paint closer to the surface making them look even better.
    Yes I just spray them down and let them sit overnight
  10. ScottinBend
    The solvent in WD40 is basically kerosene. It will do a very nice job of cleaning stuff, but it will leave an oily residue, that is it's job. Displace the water and leave a bit of oil behind.
    I have been using it (and brake cleaner) for years instead of a parts cleaner for that very reason.
  11. moreorless
    moreorless New Member
    Aug 17, 2009
    343
    14
    In a pile of sawdust.
    I'm speechless.
    ....Les
  12. rkw
    rkw Well-Known Member
    443
    #12 rkw, Jun 18, 2011
    You should try to mask off the tire as much as possible because WD-40 destroys rubber. Do you know the red straw that comes taped to the can? I had the bright idea to store the straw using a rubber band around the can, and wondered why they didn't do that. Tried it a few times and the rubber band always disintegrated.
    The new style cans of WD-40 now have a flip-up "smart straw" that are part of the nozzle and not a separate straw that you can lose.
  13. mimini1
    mimini1 New Member
    Dec 2, 2009
    104
    11
    WOW, I'm speechless!
  14. DneprDave
    Rubber bands are latex rubber, everything dissolves latex. WD-40 won't affect tire rubber at all.
    Dave
  15. Rae
    Rae Club Coordinator
    Oct 14, 2010
    907
    Oregon
    Like my Dad says, duct tape and WD 40 can fix the world!
  16. ronnie948
    ronnie948 New Member
    Sep 9, 2009
    210
    36
    Daytona Beach, Florida
    What about the Rotors????
    When you spray the wheels you are bound to get some WD-40 on the Disc Brake Rotors. I would think it would have to be removed from the Rotors before driving the car. Oil & Brake pads just do not get along together very well.:confused5:
  17. Batrugger
    May 13, 2009
    463
    92
    Soldier
    Hesperia, Ca.
    Not only does it get on there, but I spray it all over the calipers to clean them too. I have had no problems from doing this. I thought I would have to be careful the first few times I hit the brakes after cleaning, but I didn't notice any difference and I was also assured by the wheel guy who has been doing this for years that it wouldn't hurt the brakes either.
  18. ronnie948
    Sep 9, 2009
    210
    36
    #18 ronnie948, Jun 19, 2011
    I don't know,
    I just can't see putting any type of oil on my brake pads. Not even WD-40. If I was going to clean my wheels with WD-40 I would take them off of the car and spray them.
    But then, If they are off the car I could use soap and water like I usually do.
    They do make a spray cleaner that will not hurt the brake pads. Eagle-1, Mcguires, among others. A lot safer then oiling the brake rotors & pads.
    Google "Putting WD-40 on brake pads" and see what other people say.
  19. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    #19 KC Jr 54, Jun 19, 2011
    WD-40 on brake components seems like a damn terrible idea. Sure it may clean it and make it look shiney. There is a VERY good reason why you shouldnt even touch the brake surface of the rotors OR the pads during install, unless you have gloves of some form on.
    As far as it "moving the flake closer to the surface"...yeah that is not physically happening either. The oily residue left behind gives the part a 'wet' look much like a very good wax does. (a good wax lasts longer then a day though) B/C of that, the flake with-in the paint sparkles more and looks to be closer to the surface.
    Cleaning wheels w/ wd-40 has a lot of merit, but you need to be careful in how you do it. Hell ive been told by a lot of 'ole-timers' that WD-40 used to be used as a one-step clean/wax...lol
  20. Justa Jim
    Being an "old timer" myself, I'm going to follow you advice and give it a try. thanks for passing this along. :Thumbsup:
