Suspension Brakes 1st Gen How much of a necessity?
Discussion in 'Tuning and Performance' started by PhryRice, Jun 20, 2011.
  1. PhryRice
    PhryRice New Member
    May 8, 2011
    12
    I have a bone-stock r53 suspension and I'm going to be buying some VMaxx coilers before the end of the summer. My financial's are a bit limited because they mainly go towards my schooling, so I'm asking for all you MINI and suspension gurus for your words of wisdom and guidance :ihih: So here is my question. How necessary are the following to accompany and complement my VMaxx coilers for reliability, longevity, rideability?
    • camber plates
    • control arms
    • brushings
    • end links
    • sway bar
    if you can think of any more necessary suspension components/upgrades, please feel free to add.
    a few more qualifiers:
    Just a college kid, so money is a concern :mad2:
    Not interested in tracking the car since I'm buying VMaxx's (at this point)
    Not a Guru, but here goes...
    How many miles on your R53? If it has more than say 60K I think lower control arm bushings would be a good place to spend a bit of that money. Since it is a street driven car I'd tell you to buy a swaybar. That would be a good bang for the buck mod. Save the rest of your money for school.
    Just my .02... :)
  3. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    I agree with Crashton here, how many miles? You really should get your current suspension in good shape before modding it. Otherwise you blow all your money on mods then have something worn out and not be able to afford to fix it.
  4. ScottinBend
    .....and why the coilovers? Wheel gap?
  5. BThayer23
    Unless you're getting a really good deal on the coilovers, you might have a better time with just lowering springs. Waaaay cheaper.
  6. cct1
    +1 on that. Thing is, you're looking at doing some very worthwhile suspension mods, and pairing that with a so-so coilover. If you're going to hit the track, I'd consider upgrading/replacing all the worn parts, doing the sway bars and camber plates, maybe do the lowering springs, and hold off on the coilovers until you can get exactly what you want. Which many times can be found for cheap on the marketplace here or at NAM.
    Lots of good advice here..... :Thumbsup:
  8. PhryRice
    PhryRice New Member
    May 8, 2011
    12
    The car is right at 40k, and I appreciate the frugal advice. This is what I was looking for.
    By current suspension, you mean my stock suspension?
    You found me out...:blush2:
  10. PhryRice
    PhryRice New Member
    May 8, 2011
    12
    650 shipped is a pretty good deal for the quality that is the coilovers are rated at. I would do the lowering springs, but I just love the adjust-ability of coilovers.
    I would like to know which parts of my suspension would have trouble handling the new coilover or would be the first to go out. Tracking the car wouldn't happen until get out of college...:sad:
  11. PhryRice
    PhryRice New Member
    May 8, 2011
    12
    Look beyond that one item on the site. You will probably find it funny once you see more of what they offer.
  13. BThayer23
    Stick around, the jokes get worse. :biggrin5:
    Adjustable rear control arms will help bring your rear camber back into spec, otherwise you get bad tire wear. You don't need adjustable camber plates, or a thicker swaybar. New poly control arm bushings are nice, but not necessary, either.
    Have you seen the Megan coilovers? They're a little better quality than the VMaxx, and they come with adjustable front camber plates, too. Plus the spring rates are higher, which you'll need if you're lowering the car. I'm not very well versed on the VMaxx coilovers, but last time I checked they had a reputation for running soft springs to keep the OEM ride and lower the car. On the MINI, with its limited travel, you end up riding the bump stops all day long, and the ride is harsh.
    They might sell a sense of humor at KaleCo. I think it's on the page with the muffler bearings. :crazy:
  15. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Depending on the year of your car, you might have some adjustability in the rear lower control arms (05 & 06 are adjustable). Even with stock adjustable rear lower control arms, if you go lower than about 1/2" - 5/8" you will probably want aftermarket adj rear lower control arms to correct the rear camber after lowering.
    Since money is an issue and you do not plan to track the car, I would suggest using the money for shorter springs ($230), fixed camber plates ($180), 19mm rear sway bar ($220), and adj rear lower control arms ($240). Total would be around $870.
    If you go with the coil-overs for $650 you will still want adj rear lower control arms for another $240 so at a minimum you will be at $890.
  16. Justa Jim
    I just had this package put on my car and the handling is fantastic with the stock shocks. Add camber plates and you are not much above the price of the coil overs and more bang for your buck
    WMW Suspension Package - Way Motor Works
  17. BThayer23
    No doubt Way's package is a good selection of parts and creates a street car with superb handling, but if you just want to slam the car on a low budget, go for the VMaxx coilovers. The TSW springs will still leave you with a 2-finger gap in front and a 1-finger gap in the rear. You can go lower on coilovers. Eibach springs are good for lowering, too - I think they drop a little over an inch, where the TSW springs drop about 0.75". But you'll get more control over the drop with the coilovers.
  18. cct1
    +1 again.
    You'll have to decide what your goals for the car are. When I saw your first post, it looked like you were heading toward the track.
    If you want to go low, vmax will be fine, but probably not first choice for the track.
    On the other hand, if it's a drop that you're after, and not strictly performance, you really don't need to do anything with the sway bar (although you can get those used for cheap, and a decent sway bar used is just as good as new), and you really don't need front camber plates, although your bushings may be shot.
    You probably will need rear control arms though--there is a little adjustment there on the later models, but not much (I have a 2006).
    To make it easy, just give Way a call--he'll be able to put something together for you that jibes with what your goals are pretty easily, and for a reasonable price.
    Crashton, for what it's worth, I thought that link was hilarious, I could find myself buying some stuff from there (synthetic blinker fluid anyone?)...:biggrin5:
    Just wish I would have thought of it first.
  19. cct1
    It's not that any part would go (except for the bushings), but that you'd be better of with a sway bar and camber plates first, rather than coilovers first, and swaybar and camber plates second, for the track, if that makes sense. But it looks like your primary goal is the cosmetic drop--so the priorities change.
  20. PhryRice
    PhryRice New Member
    May 8, 2011
    12
    Not that I didn't think the site was funny. I just thought that you were trying to take a shot at me because I'm more interested in the drop than the performance.
    890 + the option of adjustability!
    Yeah. I don't get why everybody thinks I want to track my car. Maybe I wasn't clear, but I thought my first post said I wasn't interested in tracking (under "qualifiers"). I know that VMaxx's aren't exactly made in mind for extreme g-forces when cornering on the track.
    My end-goal would be upgrade the whole of the suspension (control arms bushings, sway and strut bars, bump stops, camber plates, end links, wheel spacers, extended lug nuts and anything else that should be replaced), but my budget won't allow it. I realize that the suspension operates in an intricate system and to change one component without regard to any other part would be ill-advised.
    My question restated: which part of the suspension should I add first to complement my coil-over upgrade in regards to reliability?
