Exterior 1st Gen How to open the Bonnet if cable fails
Discussion in 'Tuning and Performance' started by Norm03s, Sep 29, 2012.
  1. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    So, I pulled the release and nothing happened. I am guessing that the cable has slipped out of the release lever arm just when I need some more stuff to do. It worked great last time I opened it, the car has been parked for three weeks, no damage to it.
    Anyone dealt with this little (major) inconvenience before?
    HELP:mad2:
    Remove the right wheel, then the inner finder liner, and release the catch manually.
    The latch looks like this.
    Source - MINI2
  3. Norm03s
    Norm03s New Member
    534
    Thanks Nathan!
    And I'll tie wrap that sucker too.
  4. Norm03s
    Norm03s New Member
    534
    Looks real simple with the bonnet up but the head light is in the way. :mad5:
    Why out of the clear blue does this crap happen???
  5. Norm03s
    Norm03s New Member
    534
    Okay, for the next person that has this happen. In Nathans picture you see the blue sleeve on the cable attached to the latch, drivers side has a white sleeve at the same location. All you need to do, is use a long shank screw driver and push the lever where the sleeve is attached forward to release the latch.
    I am guessing road grit had gummed it up so it wasn't releasing, both cables were in place, cleaned and lubed with PB Blaster works great now.
    Looks like the latches are independent so you need to do this on both sides; remove two front wheels, remove both wheel liners, etc. Is that right?
  7. Norm03s
    Norm03s New Member
    534
    Yes Steve, that is correct. Try the easiest one first, if that one doesn't do it try the other.
    I always keep those things clean & lubed. I also put a couple of zip ties on each one to keep them in place. So far so good. :fingerscrossed:
  9. Dave.0
    That's some food advice for us with older cars. I am going to add this of my things to check.:Thumbsup:
    Thanks
  10. BlimeyCabrio
  11. SooperCooperInfo
    May 31, 2009
    78
    Retired aircraft salesman
    Land of Oz
    I have since day one kept them clean and lubed. Thanks for the heads up on the tie wraps--great idea. Just went out in the garage and secured the cables.
  12. BThayer23
    It doesn't take much to dislodge the cable ends - mine escaped after a vigorous engine bay cleaning.
  13. BlimeyCabrio
    I've been fortunate enough not to have this problem in 6 years and 122k miles... but now I'm paranoid. :crazy:
  14. BThayer23
    It's actually easy to remedy, especially compared to other cars. Just pull the wheel well liner and stick your longest screw driver in there. Most other cars have a lot more sheet metal isolating the engine from the wheel wells.
    The R56 looks like a bear to get to. Clean & lubed. :fingerscrossed:
    I is now paranoid too..... :crazy:
  16. Norm03s
    Norm03s New Member
    534
    And I wanted to do something else today.
  17. Norm03s
    Norm03s New Member
    534
    All better now.
    Add this to Spring things to do to MINI.
