Exterior 1st Gen How to remove OEM beer can exhaust tip?
Discussion in 'Tuning and Performance' started by Ofioliti, Jun 2, 2010.
  1. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    I am hoping to remove my oem exhaust tips to replace them with something else. I read elsewhere that you need to use a 3 mm Allen wrench in the hole in the bottom of the tip. Someone also mentioned that it needs to go in at a slight angle.
    I can't seem to find the hex hole that the wrench goes into. I wiggled the tip of the wrench all around and can't feel any hole for it to drop into. :confused5:
    Has anyone done this and have tips? (Is the hex hole centered? Do I have to angle the wrench towards the back f the car or the front?)
    Thanks!
  2. lotsie
    stagehand/part time detailer
    Right here
    Your skinny, lay on your back and have a look:lol::Thumbsup:. It should be centered, straight up and down. But it could be full of crud, which may be why the wrench won't go in.
    Mark
  3. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    I did, but it was too dark to see anything. :crazy:
    I'll take another look tomorrow with the car on the ramps.
    But just straight up eh? You might be right---full of crud. :eek6:
  4. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Straight up. They're up there.
  5. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    OK, like the way I like Vodka.
  6. Metalman
    #6 Metalman, Jun 2, 2010
    You might want to squirt a little liquid wrench up in those holes and let it soak overnight before you go at it with the allen key tomorrow.
    Or Vodka, it might work, something I haven't tried.... but yeah, it might work:D
  7. lotsie
    Right here
    Sounds like he like Vodka:lol:
    Mark
  8. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    Will do. Thanks!
  9. moreorless
    moreorless New Member
    Aug 17, 2009
    343
    14
    In a pile of sawdust.
    When you get them off, and if they're not scratched, don't throw them away.
    Send them to me. :Thumbsup:
  10. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    He he. I think I'm going to polish them and put them in my Mini "altar" in the basement. :D
  11. rkw
    rkw Well-Known Member
    443
    There is a picture somewhere of a set made into pen holders. You could get creative with ideas.
  12. JCC
    JCC New Member
    Dec 15, 2009
    190
    Installation Manager
    Sachse, Texas
    I'm only a couple of months late posting this, but was thinking of changing out my tips as well. I would think most replacement tips would need to be spot welded on, but I'm sure many of them use a screw to secure them.
  13. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Please light a candle for me :cornut::crazy:
  14. Nick5811
    Nick5811 New Member
    Sep 22, 2010
    36
    Sooo....
    ...did you ever get them removed? The holes on mine are on the bottom, about halfway in, and I used the multi-bit torx from Autozone to unscrew them. The screw is mounted at about a 45* angle, and then they just pull off. It's ugly as hell without the tips, and there's a little support bracket that keeps you from putting any other tips on (without cutting).
    I've been having a hell of a time finding new tips or a shop that can put new tips on without charging me an arm and a leg for 'modifying' them. What has everyone else done about tips?
  15. ScottinBend
    OEM Sport tips for me.
  16. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    I confess, I have not gotten them off yet. :blush2:
    I haven't actually tried again yet. Maybe tomorrow. :rolleyes5:
    So, I'm not sure what you mean by a support bracket preventing other tips from being put on. I guess I'll see tomorrow if I get to it.
  17. Nick5811
    Nick5811 New Member
    Sep 22, 2010
    36
    After you take off the tips you'll see a small flat piece of metal welded to the top of the exhaust pipes about 5" in from the tips. Most aftermarket tips are longer than 4-5" so if you wanted to put new clamp style tips on, you'd have to cut this piece of metal off. I'm sure it just helps to prevent rattling and keep the tips looking straight and even.
    I really like the tips on that millitek (?) exhaust kit that always pops up on the forums, but I'm not ready to spend a few hundred on exhaust quite yet.
  18. Firebro17
    I've decided I'm not going to remove 'em after hearing the story behind their design history... Hell I'll probably put 'em on the JCW exhaust when I change it over some day... :beer
  19. Ofioliti
    Ofioliti New Member
    35
    Professor
    ... always curious
    I see. Thanks. I was hoping to get something like this:
    and engrave "One" and "Ball" on each tip (I have the one-ball mod).
  20. JCC
    JCC New Member
    Dec 15, 2009
    190
    Sachse, Texas
    What do those look like?
