1st Gen R52 Cooper Convertible How to Replace Convertible Top Rear Weather Seal
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by mhourican, Jun 26, 2017.
  1. mhourican
    mhourican New Member
    Jun 25, 2017
    6
    I have a 2007 JCW convertible. The rear weather seal for the top is disentigrating. I ordered the left and right seal and will attempt to replace the old ones myself. I've read a bit on the process and I know I have to release the top to get to the screws. But, I have a question. Do I have to use new screws? I think I read that one or more on each side should not be reused. Appreciate any clarification you can provide. Thanks in advance!
    6,322
    Sorry I'm no help but here's a bump. Some one here can help.
  3. cooperjet
    cooperjet Well-Known Member
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    I haven't done mine yet but I believe you can reuse the screws. I would think they wouldn't be that expensive but the prices they want for the trim these days is just batshit crazy so who knows. Make sure you take your time and be careful with the brake light. It sounds like they can be fragile.
  4. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    I did mine and re-used all the screws. AND, I didn't screw anything up, which is not the norm for me. That should show you how easy it is.
  5. mhourican
    Jun 25, 2017
    6
    Thanks for the post. Hubby and I will take a look at it today.
  6. mhourican
    Jun 25, 2017
    6
    We did it!
    We did it. We replaced the convertible top rear trim. The trim is held in place by 8 torx (star shaped) head screws on the outer edges and 4 slightly longer torx head screws in the center of the left and right trim pieces.
    I did not put any silicone under the trim though. Should I have done that too?
    It looks good.
  7. mhourican
    Jun 25, 2017
    6
    I did not have to replace the screws. FYI, there are 12 total torx head screws. The four nearest to the license plate are slightly longer than the ones on the outer edges.
