HPFP problems... The gremlin is back
Discussion in 'MINI' started by melissa26m, Jun 1, 2016.
  1. melissa26m
    melissa26m New Member
    May 17, 2016
    69
    Ok ladies and gents. Anyone have to replace a HPFP in their Cooper?
    Backstory definitely running like a bucking horse. Falls on its face at low rpm and def running on less then full power. I'm pretty familiar with engines..... I'm a racer so.... I can talk motors.
    Code reader not throwing any codes at all.
    She's goes to shop on Monday.
    Motor on #kcco.
  3. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Plugs and coils
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Mine went out a few months ago, but not out completely. I got a check engine light a couple times within a 2-3 week period. A code came back as a failed HPFP. It didn't really fall on it's face in the low R's, just felt less torqey under boost didn't buck or stutter. I'd do coils, plugs(if you haven't recently, if you have go back to stock) and that pump Dave.0 linked you too. Really though, it's a MINI, Could be anything :)
  5. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
  6. ZippyNH
    Cooper...gen1 and gen2 don't have a HPFP...
    No direct injection for you!
    Gen2 S.....THEN YOU HAVE A HPFP....
    Think you have a 2010 clubman...non-s...
    If you don't know when the plugs were last changed, I'd start there....they don't seem to last on a gen2 like they should.
  7. melissa26m
    May 17, 2016
    69
    Just did the plugs.
    Ran the chevron techron additive through it.
    Non S clubman.
    Motor on #kcco.
  8. eMINIparts
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
  9. melissa26m
    May 17, 2016
    69
    It better be something cheap. Or she's going buh-bye.
    Motor on #kcco.
  10. eMINIparts
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
  11. MCS02
    6,317
    Carbon build up in the intake? Time for walnut blasting
  12. ZippyNH
    Nope....only on the DI cars....
    Justa's don't need to have walnut shells shoot at them....
    With coils....in my experience they usually give a code on most cars when they get flakey....
    Hope it's an easy fix!!
  13. melissa26m
    May 17, 2016
    69
    Yah me too. Like I said if it's not... She's going buh-bye. I don't have time for an unreliable car. I travel to much.
    Motor on #kcco.
  14. melissa26m
    May 17, 2016
    69
    Ok so everyone's talking coils. Plugs have been done.... Can't find a code indicating coils.... No misfire codes... How do I check the coils???
    Motor on #kcco.
  15. Guapish_Fliver
    Guapish_Fliver New Member
    May 31, 2016
    272
    Pimpin
    Da wess
    #15 Guapish_Fliver, Jun 2, 2016
    You better not "omit" the issues to the new purchaser or karmas coming to get you...
    The chick I bought my car from probably died as a result.
    :yikes:
  16. melissa26m
    May 17, 2016
    69
    I would trade it in....
    #kcco.
  17. Metalman
    ^^^ If it's running like crap when you get it appraised, they will deduct accordingly... Just make sure it's not some simple thing..
    A good code reader will point you in the best direction with fixing the problem.... That's much better than changing parts willy nilly...
  18. melissa26m
    May 17, 2016
    69
    Code reader said nothing was wrong. She goes to shop on Monday. The code reader also said my car only had 40k miles when it has 58k. My friend owns a shop and has excellent code readers also said nothing... So off to mini shop she goes.
    #kcco.
  19. Dave.0
    Good luck, hope it's cheep. :fingerscrossed:
  20. Metalman
    MINI and cheap are very seldom used in the same sentence.....
    Find a soft spot where you can fall down when you get the estimate...
    Hope it's not too painful...
