1st Gen R53 Cooper S HVAC cluster light out
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Jabbles, Jun 4, 2012.
  1. Jabbles
    Jabbles New Member
    24
    HVAC service
    Sarnia, Ontario, Canada
    I noticed Saturday on my way home from an evening out with some MINI friends that my HVAC cluster has a bulb out. I have an 05 with manual HVAC controls. The left half is out. I did a quick search and could not find anything. How difficult is this to repair? Should I buy several bulbs and replace all at the same time?
    I'd say if you are going to the trouble to dissemble to replace the burned out lights, yep do them all while you are there.
    This the part with the burned out bulb?
    Looks like you'll need to preform surgery on this and probably solder in some bulbs. I'd bet they are directly on the circuit board.
  4. Jabbles
    Jabbles New Member
    24
    HVAC service
    Yep that is the one. I kind of thought that is was not a simple bulb swap.
    It certainly can wait, aside from looking a bit goofy at night everything works.
