1st Gen R53 Cooper S I NEED HELP!!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by willdoe, Aug 12, 2013.
  1. willdoe
    willdoe New Member
    Aug 12, 2013
    27
    9
    heres the story :
    i got an offer yesterday from my cousins fiance to buy his 2006 mini S convertable. it has 82,XXX,all leather. its pretty clean with one small problem....
    he says the timing "belt" went... soo he doesnt actually know whats wrong. he told me 1000$ and its mine.
    i just need to help in deciding. i guess the serpentine belt went it was late when i went and looked at it. i have heard that it has an electrical problem from them. i forgot to ask.
    so heres the questions is it worth it? i would really like to have a newer car. i currently have a 1976 datsun 280z 2+2 and a 1995 jeep cherokee. so i could use something nice for school. and i wouldnt say im a mechanic but i definetly know my way around an engine bay.
    Thats not a lot to go on, but the 1st Generation MINI's, which this is, are clearance engines. Meaning that the valve train is not likely to get all bend and ding pistons if the timing chain has really broken. That does not happen often in these cars either.
    If it just the belt that has broken the fix is rather easy. Since that belt also turns the alternator it is possible that is why they think there is an electrical problem as well.
    I'd go back over there and take a good long look at the car again. Take some pictures too. Possibly we can help diagnose the issue and get you running. This could be one heck of an opportunity for you.
  3. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    What nate said-if it is the SERPENTINE belt, the cause copuild be a bad crank pulley (harmonic balancer) or tensioner or idler pulley-all relatively inexpensive, easy fixes. OTOH if you dont want it for 1k I'll take it!
  4. ScottinBend
    $1K.......I'd jump on it and then get it to a MINI repair shop and get it fixed.
  5. MCS02
    Yea what they said! Nathan is spot on.
    And welcome to MA
  6. agranger
    1,486
    If it is just the SERPENTINE belt that broke, that's a fairly easy fix... here is a How-to article: Replacing the Serpentine Belt on an R53 MCS - Library
    It is possible that the belt got old/worn/cracked with age and just died, but it is more likely that something else caused the belt to break... probably the crank pulley failing (harmonic balancer). There is a how-to on that as well: Replacing the Crank Pulley - Library
    I'm pretty sure that the R53 has a timing chain. If that went, then you are going to have several thousand in repairs, but even $3k of repairs + $1k for the purchase = $4k which is a STEAL for a 2006 MCS 'vert. Buy that car and run! It would sell for $8-14k if it were running and in good shape. Hell... if you don't want to buy it, send me his phone number. I'll take it as a project! I sold my R53 about a year ago and miss it dearly. :D
  7. willdoe
    willdoe New Member
    Aug 12, 2013
    27
    9
    well all that being said. i will jump on it! im going to get it tonight and start tearing it apart. dont worry about the pictures ill take a ton. ill show off when its in my drive way later haha.
  8. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    #8 Norm03s, Aug 12, 2013
    Welcome to MA.
    I think this is an invitation to get a MINI, what an opportunity.
    I'd would jump on this, quick.
  9. Norm03s
    Norm03s New Member
    534
    Op's, I was a bit late, by the way the R53 has a chain drive Cam, they are very reliable and have not proved to be problematic as in later models, i.e., R56.:biggrin5:
  10. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    welcome to m/a
  11. 10Nathan10
    10Nathan10 Member
    Mar 16, 2013
    151
    24
    Michigan
    For a thousand bucks worst case if you can't fix it you could part it out and make a profit.
  12. willdoe
    willdoe New Member
    Aug 12, 2013
    27
    9
    im going in an hour or so to get it. im gonna get it and take lots of pictures. and start cleaning it out
  13. McFly
    McFly New Member
    Jul 6, 2013
    39
    9
    IT
    Central FL
    $750 and I'd fix it myself....
  14. willdoe
    willdoe New Member
    Aug 12, 2013
    27
    9
    GOT IT! 1000$ for the car and 125 for a tow truck. i got the battery out right now chargeing over night . it turns out it only has 70,XXX miles.... so hopefully there really is nothing wrong with it.ill do more investigateing tommorow when its light out
  15. MCS02
    You lucky Dog!
  16. RallyMini370
    I need a bargain like that. $1000 to buy , $2000+ to fix, $1000 to ship to CR
  17. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    I am very very jealous....Hope it turns out to just be a drive belt and a tensioner..:D
  18. willdoe
    willdoe New Member
    Aug 12, 2013
    27
    9
    so when you go to crank it , it just sounds like the starter is clicking like its bad. i dont think there is any motor problem to be honest. i think there is an electrical problem. but im not sure yet. when we plug the OBD scanner in it doesnt turn on like it supposed to. so i cant actually test the trouble codes. pictures to come later.
  19. Nathan
    Sounds like the first thing you need a known good battery.
  20. willdoe
    willdoe New Member
    Aug 12, 2013
    27
    9
    pictures?
