2nd Gen JCW I need some clarification about the JCW front bumpers
Discussion in '2nd Generation: 2007+ R55 through R61' started by knoteasy25, May 31, 2011.
  1. knoteasy25
    knoteasy25 New Member
    May 31, 2011
    I have a 2009 mini cooper s that is missing the entire front bumper assembly
    I am thinking about replacing it with a jcw front bumper
    are there different kinds as in one without fog lamps or is it one jcw front bumper which uses the same foglamps as the standard cooper s
    thank you
    Marlon
  2. Metalman
    This might be helpful. I also have a 2009 and I replaced the standard "S" bumper (Skin) with the JCW Aero bumper skin. The "S" fog lights need to be used with the Aero bumper.
    When you say it's missing the front bumper, you do mean the skin correct? You still have all of the bumper impact beam structure correct?
    Here is the thread I started.... I got my JCW Aero bumper from Aaron at Outmotoring.... He's a great guy....:D
    http://www.motoringalliance.com/forums/jcw/4057-r56-jcw-bug-catcher.html
  3. david in germany
    david in germany New Member
    Dec 15, 2010
    250
    As Metalman said, they use the same fog lights. If you do get the JCW bumper I would suggest getting it with the brake cooling package. The only additional needs you will have to install it is to cut the fender liners where the ducts meet up to them.
  4. CHKMINI
    I suggest that you give Aaron a call at Outmotoring. He has set a bunch of us up with JCW front bumpers and he understands what is needed and what is compatible.
