Brakes Wheels 1st Gen Tires Identify this wheel?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by mrntd, Dec 5, 2012.
  1. mrntd
    #1 mrntd, Dec 5, 2012
    My new car came with these wheels. I really like them and they are very light for 18". But I have no idea what they are. Any wheel experts out there what to guess?
    #2 Nathan, Dec 5, 2012
    Might help if you shut off the script that doesn't allow a hot link to your own server Nick.
  3. Metalman
    Nick.....
    No thieves on M/A....:eek:
    Vapor wheels I'd guess. :yesnod:
  5. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Never seen those before.
  6. cooperSml
    cooperSml New Member
    Jul 20, 2011
    162
    54
    Living on South
    Stolen Image? It must from SHARP IMAGE group.
  7. mrntd
    I always forget that because I can see it. So lets try again.
    Another question does a MINI require hubcentric wheels where the wheel must center on the hub not the bolt pattern?
    Looks like a Drag DR-35. You'll have to pull the wheel and look at the marks on it to determine the manufacturer though. There are so many different brands that have that design it may as well be a generic design.
    Yes to hubcentric for best results.
  9. cooperSml
    Jul 20, 2011
    162
    54
    Living on South
    Nathan I think you are correct about the wheel
    Drag DR-35 18X7.5 5x100/114 45mm Flat Black
    The only think the wheel he is showing on the car the red looks like was painted. When looking the DR-35 the lip it is just on the outside. But it does looks like the DR-35
    Nice looking wheels although those 18 inch ones make the brakes look tiny. Speaking of brakes red calipers would look very good with those black & red wheels.
    Hubcentric rings for a smooth rotation.
  11. mrntd
    Nope the center and the area between the spokes on the rim are different. I pulled the wheels there are no names any where on them.
    Now I have to find hubcentric rings!
    I believe Aaron at Outmotoring carries them. Or hit up the local Discount Tire store.
  13. minidiver
    minidiver Member
    Jun 24, 2010
    31
    You can also find them on eBay. Measure the inside diameter of your wheel center and get that size by 56.1mm.
  14. mrntd
    Thanks for the concentric ring info. Got a set at Discount Tire today for $16. Solved the vibration problem.
  15. JP Money
    JP Money New Member
    Feb 7, 2012
    11
  16. mrntd
    Nope. I finally found out what the wheels are Hayame Time Attack. But I still don't want to hurt them because they aren't cheep. $750-$950 each.. ouch. I knew the the guy I got the car from had money but wow.
    Thanks for all the suggestions
  17. CHKMINI
    Let's put them on GNAT......
    Wow Nick solid gold wheels!!! Crazy money fir sure.
  19. Nathan
  20. mrntd
    Okay, I feel better now. It felt weird thinking I had wheels that were about 1/3 of what I paid for the car.
