2nd Gen R56 Cooper S Identifying Two Pin Connector
Discussion in '2nd Generation: 2007+ R55 through R61' started by makg, Sep 26, 2017.
  1. makg
    makg New Member
    Sep 26, 2017
    Hey guys, I changed my flywheel and clutch this weekend and everything is back together. Very glad to get rid of my DMF rattle. However, during reassembly I could not remember what the other end of this plus goes to. I’ve looked all over and even did a part number search to no avail. It’s a two pin plug mounted right next to the washer bottle.
    Anybody know off the top of their heads? Thanks!
      File size:
      226.4 KB
      277
      File size:
      174.1 KB
      276
    Welcome to MA! What year and model Mini do you have?
  3. makg
    makg New Member
    Sep 26, 2017
    2010 R56S w/ N14
  4. jetsr6
    jetsr6 Member
    Aug 31, 2017
    95
    79
    Driver
    Loganton, PA
    Did you figure it out yet?
  5. agranger
    A google search with R56 and 7514237 turned up some references to AC/Heat blower fans (but the link just took me to ebay). So maybe it connects to the AC somewhere?
    I also found it on Real OEM as a part of a battery cable harness (which makes some sense, given it is an electrical connector), but not for an R56.
  6. agranger
    #7 agranger, Sep 26, 2017
    and here, looking like it feeds into the air pipe from the filter to the engine.
  7. makg
    makg New Member
    Sep 26, 2017
    #8 makg, Sep 26, 2017
    Not yet. I've searched for the matching plug to no avail. I'm probably going to remove the left inner fender today to get a better view. I'm hoping it's related to a yellow DSC and brake indicator on the dash.
    I saw that it came up for an R60 on RealOEM, but that orientation and position doesn't look correct.
  8. agranger
  9. makg
    makg New Member
    Sep 26, 2017
    If you're referring to that breather sensor, it's been accounted for. The plug in question is mounted next to the washer bottle behind the fresh air intake tube.
  10. agranger
    it sure looks like it clips into a sensor on that air line running from filter to turbo, near the oil like for the turbo
  11. agranger
  12. makg
    makg New Member
    Sep 26, 2017
    My breather plug has been relocated as shown:
  13. MCS02
    This looks kind of like it. This is on my R58 with the n14 engine. You can see on my car it plugs into something under the air intake hope thi helps
  14. agranger
    Find it yet?
  15. makg
    makg New Member
    Sep 26, 2017
    Negatory, going to do some dismantling tonight to try to find its mate.
    Here's what I'm referring to.
  16. MCS02
    Good luck. But um is it faster? You may want to leave it unplugged.:D
  17. makg
    makg New Member
    Sep 26, 2017
    ECSTuning told me that it was a sensor plug for an optional alarm.
  18. MCS02
    Wouldn't it be nice if they labeled the connectors so we don't drive ourself crazy looking for the place to plunge it in!
