Suspension Brakes 1st Gen If only they made these for the MINI.
Discussion in 'Tuning and Performance' started by WolfGTI, Oct 15, 2010.
  1. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
  2. Rally
    Rally New Member
    50
    Ohio
    Seems like most of the same benefits could be had with these
  3. ScottinBend
    Those are a great alternative to the poly LCA bushings. Been loving mine for 3 yrs now.
    MiniMadness has, or did have, a tubular LCA replacement with a solid bushing.
  4. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
  5. TATTRAT
    TATTRAT Well-Known Member
    496
    399
    Executive Chef
    NoVA/DC
    damn it, my mod list is growing every time I log on here. . .
  6. versus
    versus Active Member
    Sep 8, 2009
    553
    87
    Join the club. I didn't even know these existed and now I want some.:cryin:
  7. WolfGTI
    May 21, 2009
    387
    217
    NJ
    I don't like the whole idea of securing my control arms with set screws plus I don't think the ALTA stuff will like the salt / moisture that comes with winter usage.
  8. Doggybags
    Doggybags New Member
    I know there are fans of the Alta PSRS that swear by them. I have them because I got them at a steep discount. I have tried everything, red loctite, welding, grease... They still rattle. A lot.
    Get the Powerflex, that's what I would do even if I had to do it over again with the steep discount.
  9. ScottinBend
    You aren't securing the LCA arms, all the set screws do is to hold the sleeve in place. There isn't any load being applied to the sleeves. The sleeve is just an interface between the hex end of the LCA and the bushing.
    Been thru the harsh winters here with no problem or wear concerns. Not sure why there are rattling problems, but I would guess that simply tack welding the ends of the sleeve to the arm, like I have done, would be enough to eliminate the sound.
  10. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    I had the exact same experience. Didnt get to the point of welding, b/c the sleeve was not the issue.
  11. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    The original post
    was for aluminium LCAs.... These should be a lot lighter! Wish they existed for the MINI.
    Matt
  12. BThayer23
    Aluminum LCA's? How much would those things cost??? :crazy:
    I believe the OP is in fact referring to the bushings.
  13. WolfGTI
    May 21, 2009
    387
    217
    NJ
    The LCA is shows for the E46 - I was infact referring to the bushings not the arm. The bushings just happened to be pictured with an LCA.
  14. ScottinBend
    The rattle comes from the sleeve rattling against the hex end of the control arm, not from the bushing itself.
  15. Onasled Racing
    Onasled Racing New Member
    Jul 19, 2010
    172
    Those are pretty for sure. But this 'design' would not work on the R50-53s. Design would work on the second gen cars though...I believe from only what I have 'seen'
  16. KC Jr 54
    KC Jr 54 New Member
    Jun 3, 2009
    402
    20
    Machine Operator
    Tyler, TX
    Thats not 100% true. The other person who removed them in this thread also welded his, and it did nothing. There are also others you have replaced the inner plastic (delrin maybe) and the rattle went away.
    With my car in the air i was able to wiggle the arm by gripping only the sleeve.
    Why would it not work on the r53 aside from the mounting arrangement ? I havent had a chance to be under a r56, i *though* they were near identical, so why would it work on them ?
  17. Onasled Racing
    Jul 19, 2010
    172
    It really has to do with the inner ball joint. The 1st gen Mini's inner ball joint pivots above the control arm thus making the rear of the arm rock, rather then rotate. The second gen Mini's ball joint is "in" the arm (as I remeber because it's been a while) like the BMWs have always been and like the one pictured. This makes the back of tha arm rotate witout that rocking motion.
  18. BThayer23
    #18 BThayer23, Oct 20, 2010
  19. Rally
    Rally New Member
    50
    Ohio
    Yup, the second gen ball joints are in the control arm, but point downwards unlike the e46 I imagine.
    Not sure why the specced the thread to be so overly long, but it's almost an inch longer than necessary with the bolt under the subframe.
    My close up of where the ball joint meets the subframe
  20. Metalman
