2nd Gen R56 Cooper S I'm new! Check engine and oil leak
Discussion in '2nd Generation: 2007+ R55 through R61' started by Jph3, Jun 7, 2012.
  1. Jph3
    Jph3 New Member
    Jun 7, 2012
    I just bought two 2007 S's for my company, and just learning about these great cars... I'm a long time jeeper, so the mini world is a little similar. More wrenching than driving :)
    Anyway, just purchased this car yesterday. Have full records and warranty for another year, but curious how I missed this.
    The check engine light just popped on... Question 1. Is there no way to read the codes from the dash? Is a scanner required no matter what?
    Question 2. Does this leak look familiar, and what did you end up doing to get it straight? (middle tube, back... Looks like a t fitting... Passenger side right next to the strut mount)
    Any help is appreciated... Will be more of a contributor when I'm a little more familiar with these setups!
  2. Jph3
    Jph3 New Member
    Jun 7, 2012
    #2 Jph3, Jun 7, 2012
    Little more info. 42k, and the engine seems to be running fine. No sputters, misses or weird noises.
  3. Justa Jim
    Welcome aboard. You need a code reader for sure. I have a justa, so that is all I can help ya with, but some "S" folks will be along shortly. :Thumbsup:
  4. Jabbles
    Jabbles New Member
    24
    HVAC service
    Sarnia, Ontario, Canada
    Welcome! What area do you live in? There are several good MINI specialists out there. Check out the vendor section. If you are under warranty though, you can save the vendors for fun stuff. Can't help on the leak but I would get the CEL checked out soon. Even if things seem fine bad things could be happening.
  5. Jph3
    Jph3 New Member
    Jun 7, 2012
    I'm in Vail CO. We have offices in Grand Junction, Aspen and Vail... So I hope to find a good mini specialist somewhere around these areas!
    Thx for the input so far, checking codes right now. Crossing my fingers.
  6. Jph3
    Jph3 New Member
    Jun 7, 2012
    Also correction... I'm out of warranty by 6 months... Maintenance plan is through Nov 2013.
  7. Metalman
    Welcome to M/A.....:D
    I assume you are talking about the smaller tube connecting to the port on the valve cover?
    That would be one of the rigid hoses leading to the intake. It's part of the PCV system (it conducts oily fumes out of the valve cover, so thats the oil leak). There is a plastic flex ring around the fitting against the valve cover. Squeeze it with your forefinger and thumb. It can be tricky to get off. just squeeze it and give it a wiggle and it will pull off in the direction towards the firewall. There is a "O" ring seal that might have gone bad.... Or maybe the hose was removed sometime in the past and wasn't installed correctly. You should feel a solid snap when it is properly reconnected. It could also be the reason you have a cel warning.
    I think the hose runs something like $60.00 or so..... And a second suggestion, don't buy it from the dealer, order it from one of our very fine sponsors....:Thumbsup:
  8. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    yup, if there is oil leaking from there you would probably also have a vacuum leak causing the CEL.
  9. old81
    1,542
    Welcome, Vail nice! If you get pressed for service work bring your MINI down to PEAK Eurosport in NW Denver Kipling and I70 area.
    Schomp MINI actually is very good at repair on the MINIs, hourly is $125 per, but they will work with you. Justin Brown is the service manager and is not an old car dog.
    Remember to stop by MITM in WP this summer, come over and introduce yourself.
    Of course, if you want join the MINI5280, we drive up your way off and on. Some of our members are in Grand Junction and the West Slope.
    I do know we will be in Vail area in September with one of our big yearly events.
    Good advice from the experts, get that leak fixed.
  10. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    The T fitting I'm aware of in that area is coupler for the inlet tubes to the manifold, #s 7/10/8 RealOEM.com * BMW R56 Cooper S Boost air duct/sound generator. There may be a boost leak there. Number 10 in the diagram only functions to redirect intake noise to the cabin, feel free to plug the T for that hose and remove the noisemaker if you wish. If above or below the coupler, and you have a boost related code, remove & clean the edges, tighten the clamps.
  11. Jph3
    Jph3 New Member
    Jun 7, 2012
    Thanks for the feedback guys. Actually got a better look in daylight today and you are right... The valve cover needs a new gasket.
    Dan, definitely let me know when the time comes closer... Would be interested in bringing both to the event. Looking at a third tomorrow as well, so we might be a little overboard with Minis by then!
    Also, got the code pulled. It read 'super knock'. We searched for awhile and couldn't find any info... Cleared it and it has been running fine since. Getting it into the shop next week either way to fix the gasket and give a better look over. Will post a pic of it here soon.
