1st Gen R50 Cooper I'm one pissed mini owner!!!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by dawnie, Apr 22, 2014.
  1. dawnie
    dawnie New Member
    Mar 8, 2014
    76
    Personal Assistant and Merchandiser
    Port Orchard,WA
    So as of yesterday I started having tranny issues... Recap* 2006 Hardtop with automatic transmission. In regular mode my RPM's will jump up as high as 5 while traveling at 25mph, refusing to shift while traveling at 50+mph and climbing a hill my RPM's drop to almost one. I am not having too many issues while in sport mode. I have had this car since March 8th and have put almost 5k miles on him. He also is not wanting to have a prompt start... In my research I'm now disgusted with what I think the issue is... CVT? The kicker... If I had the $6k to fix it I missed the deadline for the lawsuit by 20 days!!! Anybody know if this sounds like the issue and if this could be covered under WA state lemon laws?:mad2:
    I can't answer any of your questions about WA laws or CVT issues but it I hope you get it all sorted out somehow.
  3. wmwny
    4,048
    2,246
    Maybe someone from the WA group of MINI owners here can help you out. Good luck!:Thumbsup:
  4. Mr. Jim
    Not sure what year you've got, as an 2006 didn't have a "sport" mode but I thought the CVT where only in the early years???
  5. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    Any oily puddles in the garage? I'd sure have the fluid level checked and it's about time for an engine oil and filter change anyway.
  6. wmwny
    4,048
    2,246
    The MCS came out with a real automatic in '05, but the Cooper models did not get a real automatic until Gen 2, I think.
  7. dawnie
    dawnie New Member
    Mar 8, 2014
    76
    Port Orchard,WA
    #7 dawnie, Apr 22, 2014
    The sport mode I have refers to while in drive I can gently push lever to the right and then my transmission gauges change to sport and I have the option to manually shift. So here is the kicker... the man just took it for a test drive... I went along... after a 20 mile variable speed drive D.B. didn't replicate what he's been doing to me for past 2 days... Continuing assessments...
    Here is the "data" for my vin...
    Model description COOPER
    Market USA
    Type RC33
    E-Code R50 (2)
    Chassis Coupé
    Steering links
    Doors 3
    Engine W10 - 1,60l (85kW)
    Drive Frontantrieb
    Transmission automatisch
    Body color Astro Black Metallic (A25)
    Upholstery Kunstleder/panther Schwarz (K7PN)
    Production date 31.10.2006
    Assembled in Oxford
  8. dawnie
    dawnie New Member
    Mar 8, 2014
    76
    Port Orchard,WA
    Now the man has me confused... Are all automatics on 1st gens CVT with the exception of the CooperS?
  9. Friskie
    Jul 20, 2009
    1,650
    1,333
    I was fixing to post this edited version but got interrupted so here 'tis in it's entirety except for the oily puddle comment:
    Found this on another MA thread:
    2002 through 2006 model year MINI Cooper (R50) (produced June 11, 2001 through Nov. 28, 2006); and
    2005 through 2008 model year MINI Convertible (R52) (produced March 6, 2004 through July 31, 2008).
    Read more: http://www.motoringalliance.com/forums/cooper/19122-mini-settles-cvt-class-action-suit.html#ixzz2zfalyNLd
    Post #7 by minidave is worth noticing.
  10. dawnie
    dawnie New Member
    Mar 8, 2014
    76
    Port Orchard,WA
    I'm going to check the only mechanic in my area who services MINI's to see what they charge to have fluids changed... and of course take a looky see. I just dont trust mechanics I dont know...
  11. Friskie
    Jul 20, 2009
    1,650
    1,333
    Here's a resource every MINI person should have in their 'Favorites' MINI folder.
    soopercooperinfo.com
    You'll find an independent repair shop directory along with just about everything there is that has ever been done, tried or thought better of concerning MINI ownership.
  12. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    967
    727
    training specialist
    Maysville, North Carolina USA
    #12 GokartPilot, Apr 23, 2014
    Has the engine light popped on? Have you scanned for a code?
  13. MCS02
    If it is a CVT and you are only 20 days past the deadline call MINI USA. Plead your case, let them know you didn't know about the case until you started having trouble.
    I am precluded from giving details, but my sons Gurman car was part of a class action sute. I was a year past the deadline and the componay stilled helped me.
    MINI may still fix your car if it's a CVT problem. It's worth a try. Be polite but firm and it may take talking to some type of manger not just the costermer support agent that answers the phone.
    Good luck
  14. mrntd
    In most states lemon law against the manufacturer on a used car won't win or can't even be filed. Your recourse is back to the seller.
  15. Fun Size
    Fun Size New Member
    Dec 27, 2010
    Rock Hill, SC
    I have a 2006 auto Convertible with the CVT. I had issues last October that sound similar to yours. I read multiple posts on this forum and followed some advice I found. (Thank you all by the way) I had the transmission fluid flushed and had the computer reset. It didn't cost too much and was worth a try. I got lucky and it worked. I was at about 60,000 miles. The advice also recommended to do the flush every 20,000-30,000 miles.
  16. dawnie
    dawnie New Member
    Mar 8, 2014
    76
    Port Orchard,WA
    Only light that came on was after attempting to start engine Monday morning, engine didnt fully turn over and the warning light came on. I then restarted and the light has been off since...
    Does the mini have a way to access codes in the OBC display?
  17. Minidave
    4,592
    I would take it to your local dealer and see what they say, if you're going to get any help from MINI USA, it will be thru the dealer. Also, they have the machine and proper fluid to do a flush. Few if any independents do....
  18. GokartPilot
    Jan 9, 2012
    967
    727
    training specialist
    Automatics have a speed sensors on them. I had a non MINI do the same thing but it was also coding, after a little research and trouble shooting I did find a bad speed sensor, $20 later verything was good to go. Hopefully it will be something as simple as a flush or sensor.
  19. dawnie
    dawnie New Member
    Mar 8, 2014
    76
    Port Orchard,WA
    Soooo.... After a test drive and a day of no shifting issues I jump in DB to head to work and there was no starting him... Luckily I caught my boyfriend before he rounded the corner heading to work... drove my dakota, making him drive the F350... My battery is toast so this got me thinking.... when all this started, poor shifting and loss of power, it was after a failed start leading me to restart D.B... Could this all be related to the battery telling me its toast?
    Getting new battery this evening ($170 ouch) after a bit of research into type and size... I read on some other boards people who had loss of power when their batteries failed...
  20. Dave.0
    It could be, all kinds of odd things happen to MINI's with dying batteries.
    As a matter of fact Malaysia Airlines Flight 370 had a dying MIN's battery in it. :rolleyes::lol:
