Way Motor Works is so excited to announce the latest in SCCA AutoX news. SCCA has just changed the Sway Bar rule for stock class AutoX. So for us MINI owners this is the greatest news ever as you can now add a rear sway bar and stay in stock class. WMW has been using and installing sway bars for years and we can tell you that if you AutoX the bar your going to want is the Hsport Competition rear sway bar. It only weights 5.5lbs so it is the lightest on the market, but still being as stiff as a standard 22mm allowing you to get the MINI to rotate like you need.
