Impressions/Opinions of Automatic A/C
Discussion in 'MINI' started by versus, May 9, 2010.
  1. versus
    versus Active Member
    Sep 8, 2009
    553
    87
    Playing around with the "build-a-MINI" feature on the MINI website and I came across the $500 auto a/c option. Just wondering if people thought this was a must have feature because you can "set and forget" the temp or whether it was overpriced in comparison to what you get with a manual unit.
    What say ye?:popcorn::arf:
  2. lotsie
    stagehand/part time detailer
    Right here
    Turning a couple of dials now and then is not a big deal, and not having to for $500 is not worth it to me.
    Mark
  3. Ernesto
    Ernesto Club Coordinator
    May 16, 2009
    692
    750
    Oracle DBA
    Skokie Ill
    I have one of each on my 1st gen Coopers.
    The Auto temp dash looks cool with the stylized MINI logo for all the buttons, but I don't like how it chooses the fan settings (starts out high and takes a while to quiet down) or that anything 62 degrees and above is heat and below is cool (and it only goes in 2 degree increments).
    I much perfer the manual dial to set the temprature to a comfortable mix, and have the ability to mix vent locations by setting the dial in between dashboard, feet or defrost locations.
  4. Jabbles
    Jabbles New Member
    24
    HVAC service
    Sarnia, Ontario, Canada
    Never driven a car with auto temp, but I don't think it's worth it. In your house you want to set it and forget it, in a car things change from on minute to the other. It's also real easy to fine tune as you go.
  5. Metalman
    I have the auto, but use it in the manual mode for the same reasons Ernesto gave for the fan speeds.
  6. TT_Zop
    TT_Zop Club Coordinator
    May 26, 2009
    188
    Machinist
    Flint,TX
    The fan motor will drive you insane on a hot summer day till the temp comes down!!
  7. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    I love mine
    I would buy it again just for the controls feel, although in the R56 the controls are quite different. In an R53, the manual controls feel cheap to me.
  8. Minidave
    Can't you manuallly control the fan speed even on the automatic systems? You could on my '03....
    I also prefer the manual system.
  9. Metalman
    As soon as you use the fan speed switch, it disengages the auto feature on the R56.
  10. lotsie
    Right here
    That makes me wonder why get the auto, if it is not useful.
    Mark
  11. Metalman
    If I could get a "do over" I wouldn't get it. Besides, with the manual system, your MINI will be lighter.:ihih:
  12. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    No auto A/C + a manual transmission + no cruise-o-matic + no auto-dimming RVM = maybe I'm a just a hopeless control freak :yesnod: :eek:ut:
    (I am managing to survive the auto door locks and windows... :arf:)
  13. lotsie
    Right here
    I wanted hand crank windows, and no power locks, but even back in 03 they looked at me weird when I asked for that:lol:.
    Mark
  14. Blainestang
    Blainestang New Member
    Jan 16, 2010
    216
    17
    I thought about it this way. Would I pay someone $500 to adjust my A/C for me?
    No. I'm pretty sure I can handle that.
  15. BlimeyCabrio
    I like my 1st gen auto AC. When I need to override it, I do. Much of the time, I set the temp and let it take care of things. When I feel a need for full manual control, I put the top down.
  16. galoki
    galoki New Member
    Sep 8, 2009
    126
    i've got it... I found it does a decent job of keeping the temp constant. My complaint is the 2 degree increments... but being such a small interior the A/C does a good job of cooling down fast. I normaly only switch to manual on the really hot days when I want a full stream of cold air. the auto setting will slow the fan speed down and all the sun light coming in can still be a bit warm. The other thing that helps in the heat are the sunroof shades. Got a pair of those, so in the July/August heat in Atlanta, they help alot to keep the car cool.
  17. Nathan
    I never had auto A/C controls before this MINI. Being I bought off the lot there was not much choice in the matter as it was already in the car. I like the set it and forget it idea. Keep it at 68 99% of the time. About the only time I shut it off is on track.
    If I was specing out the car I'd probably not of added it unless it came in a package I wanted. However, since I do have it, I like it.
    As to adding to resale value down the road, I think only if the car was being traded at a MINI dealer would it make a difference.
  18. Wikedmini
    Wikedmini MINI of the Month - December 2009
    Aug 17, 2009
    304
    13
    meh... i cant turn it on it i want too... 90% of the time i never use AC
  19. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    I like mine. And you don't HAVE to use the auto feature. It can be used "analog" as well!
  20. YesIFit
    YesIFit New Member
    May 25, 2009
    231
    I leave mine on Auto about 95% of the time and it works fine. On a side note, I've found that the AC on my R56 is much improved over my R53, which never seemed to get past "merely cool" on summer days here in TX.
