1st Gen R53 Cooper S Incomplete VIN
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by minidux, Dec 11, 2011.
  1. minidux
    minidux New Member
    Aug 14, 2009
    11
    Oregon
    Went to register my 05 MCS and when the DMV hooked the computer up to my car the VIN number was a bunch of zeros and then last five digits of my VIN. They said I need to have the dealership boot my computer. Anyone have this problem?
  2. Minidave
    4,596
    The DMV hooked up a code reader to your OBD port to read your vin? They wouldn't just go by the number on the windshield and other places on the car? Or were they checking to see if the ECU matches the VIN? Why the heck would they do that? Did you bring the car in from out of state? out of the country?
  3. Mr. Jim
    In Jersey they hook up for emissions which will also give them the vin.
  4. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    same thing here in GA too I believe. Kinda makes going stand alone ECU a pain in the butt if you have a car built after 96.
  5. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    It is going to be the future of SMOG checks. No more tail pipe testing. All the smog certification will be done via ECU port. So having a modified engine will be a challenge in the near future in most states.
  6. ScottinBend
    Never had my DMV do that in OR.........is that a Portland thing?
  7. Minidave
    4,596
    One good reason to live here in the middle of nowhere (and probably the only one) where they don't have emmisions inspections, or even inspections for that matter!
  8. Justa Jim
    No emmisions inspection in PA. :nonod:
  9. CHKMINI
    Some cities in Ohio have emmissions testing....but not in good old C'Bus.
  10. Minidave
    4,596
    When I moved here from Sandy Eggo I had to have the vin verified on my Jag, the HiPo officer wasn't happy with my replacement engine bay vin tag that I'd stamped myself, but finding the same number both on the windshield tag and stamped on the frame members allowed me thru. Since then all I have to do is renew online.........
  11. DneprDave
    Yeah, no inspections or emission checks here in the wilds of Western Washington either!
    Dave
    I feel very lucky there is no testing as of yet in Hooterville. In fact I moved one county north so it probably not going to happen up here for a long while. :Dx10
  13. minidux
    minidux New Member
    Aug 14, 2009
    11
    Oregon
    Yea they won't use the VIN on the dash they need it off the computer. What a pain in the rear I was thinking of unhooking the battery for a soft boot? I am taking it to a shop on Friday have them boot it. I guess I am a first with this problem,I registered the car two years ago when I bought it no problem then. Thanks for input guys
  14. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    My MINI is an 2002 MCS. I recently needed to get mine smoged. What a fiasco!
    The CA VIN showed I had a smog pump (which we don't) and I had 2 anomalies which the new classification only allows one. After getting it down to one the next challenge was the emissions. I failed the first run because of none readable comparative results. In other words I was to clean. LOL I run LPG 100% of the time now so it lowered my emission level below the factory allowances. To much clean air???? Easy enough I turn off the lpg drove around the block to clear any residue and passed with flying colors. In CA you can no longer get an emission exempt certificate unless the fuel used is on their approved list and that all the oem emissions devise are still functional. Stupid considering they are not needed with alternative clean burning fuels?
  15. Person Moved On
    Person Moved On New Member
    110
    They stopped the emissions testing in Cincy 4 or 5 years ago - what a PIA that was.
  16. OldBlue
    OldBlue New Member
    Sep 7, 2010
    115
    11
    Die Shop Coordinator
    Cleveburb, OH
    Cleve-burb does. Thanks Cuyahoga county! Not.
  17. CHKMINI
    OSU lost to Michigan this year ....that means all cities that border Lake Erie belong to Michigan until next year...right?
  18. ScottinBend
    When did you start running LPG?
  19. Dave.0
    #19 Dave.0, Dec 15, 2011
    Not all of PA....:frown2:
    I am outside of Philly and we have Emisions testing via OBD.
    Check out the map of PA here to see what counties have emissions testing.
    http://www.drivecleanpa.state.pa.us/
  20. DneprDave
    I didn't know that Oregon State University ever played Michigan!
    Go Beavers!:Thumbsup::lol:
    Dave
