As of late I have been noticing the boost from the sc kicking in at 4k, backing off, then kicking in again. All in between 4 & 6k. This is all with full throttle. Any ideas?
it shouldnt have but anything is possible.have you checked your intercooler boots? or maybe your tensioner belt is slipping. so check the belt and the tensioner
what are you using to determine the boost and the rpm range? The unusual behavior you describe does not sound of the normal suspects.
Auto or manual trans? And what year is your car? Sometimes the 05-06 cars don't like the DT bypass valve.
Ditch the DT bypass valve and see if that helps. Otherwise PM BlimeyCabrio. He's got an 06 auto and knows all there is to know about intermittent boost problems, bypass valves, and the R53 auto tranny.
