Info needed: Amsoil. Sparkplugs. Etc.
Discussion in 'MINI' started by SNEEEZY - Erika, Feb 13, 2011.
  1. SNEEEZY - Erika
    1,212
    116
    Female
    Schultze is currently in the shop and should be back to me by the end of the week.
    When I get him back, it will be time for an oil change and probably sparkplugs, too.
    He currently has 72280 on the clock (mainly highway miles) and I do a LOT of very spirited driving.
    I change the oil every 7500 or so miles...
    Thoughts on AMSOIL products? Which would be recommended?
    Sparkplugs?
    I have a Screamin' Demon sitting on the shelf, along with Nulogy wires...
    Thanks in advance! :Thumbsup:
    Nology wire - waste of money but since you have them you may as well use them. The OEM wires do a great job, for some color try Kingsbourne.
    Amsoil - Fine product as well as is Royal Purple and Redline. Use the viscosity specified for your engine. 5W-30 I think but others will correct me if wrong.
    As for an oil filter - OEM all the way. The other brands may be a buck or two more inexpensive but they are not of the same quality.
    Plugs - NGK
  3. BThayer23
    NGK BRK6EQUP without a pulley
    NGK BRK7EQUP with a pulley or JCW kit
  4. SNEEEZY - Erika
    1,212
    116
    Female
    Thanks for the info! :D:D
  5. SNEEEZY - Erika
    1,212
    116
    Female
    I have a Justa...does that make a difference?
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Oil, if you change it regularly at 3-5 7k is pushing it? Oil can be expensive or sensible, the oil on sale works fine, see info on oil. Anything else is advertising hype!
    More Than You Ever Wanted to Know About Motor Oil
    Spark plugs NGK oem heat range unless you are going to do the needed work to determine another type and heat range.
    If “screamin demond” you are referring to a transformer/coil you may be better to stay with the stock coil? The material quality of some aftermarket coils are less than desirable and may actually cause problems. If you must change your coil shop for ones that have brass or copper plug towers.
    Spark plug wires are not all the same do the research and find the highest quality with the least ohms per foot.
    When you change your plugs it is a good idea to use a little thread anti-seize on the threads, if single ground electrode check the gap and when installing properly torque them.
    Be very careful about the oil plug start the threads carefully by hand and do not over tighten. There is actually a torque value but few ever take the time to do it correctly.
    Use dielectric grease on spark plug wire boots.
  7. jcauseyfd
    jcauseyfd New Member
    May 25, 2009
    201
    31
    Graham, NC
  8. ScottinBend
    Don't waste your money on the oil, just go for a quality major brand synthetic and keep the intervals at an acceptable length. You will never have a problem as long as you use an OEM filter.
    And +1 on what the others have said.......lol
  9. BThayer23
    NGK BKR6EQUP is the right spark plug for R50, R52, and R53 (non-JCW).
    R56's use a different plug and a different socket, and I can't really pretend to know what I'm talking about with second generation MINIs. =)
  10. Justa Jim
    I've been reading everything you have posted for months and now you tell me you know nothing and the R-56. Well, crap. :cornut:
  11. Jason Montague
    :cornut: Never a dull moment. When I really need a laugh(like now),I can always get it here on MA!:Thumbsup:
  12. BThayer23
    :lol::lol::lol: :beer
    Like my dad always says, the advice is free, but you get what you pay for. :D
  13. Justa Jim
    Your dad is a wise man Ben. :lol:
    Free & worth every penny. :p
