2nd Gen R56 Cooper S Installing Rally Lights?
Discussion in '2nd Generation: 2007+ R55 through R61' started by dchernikoff, Aug 29, 2016.
  1. dchernikoff
    dchernikoff New Member
    Jul 19, 2016
    26
    Software Engineering Manager
    Palo Alto, CA
    Has anyone installed Rally lights on their S? I really like the look of them. I'm considering the kit from ECS:
    https://www.ecstuning.com/ES174047/
    It's about half the price of the ones from the dealer and they look the same. Has anyone done the install? It looks like the connectors are plug-and-play. It says you need a different grille with mounting brackets, and a switch for inside. How hard is it to route the wires into the switch area? I don't mind taking off the grille, the dash, etc., as long as I can get it all back together!
    Are there any other kits I should look at?
    Thanks for any info or advice.
    -Dan
    I wired my light to come on with the bright lights. If you do it that way you don't have to run wires inside the car. If you want them on a separate switch it's still not hard you just have to find a place to run the wires in to the passenger compartment. I believe out motoring sales brackets.
    Is your mini a second Gen? If so take a look here. Out motoring has several lights to chose from and they have the brackets near the bottom of the page.
    http://www.outmotoring.com/mini-cooper-accessories/1-lighting-tint-lens/
  3. dchernikoff
    Jul 19, 2016
    26
    Palo Alto, CA
    Thanks for the info and the link!
    -Dan
