2nd Gen R60 Countryman Installing Recaro Sportsters
Discussion in '2nd Generation: 2007+ R55 through R61' started by wzabrouski, Mar 16, 2015.
  1. wzabrouski
    wzabrouski Active Member
    32
    Executive Director
    Keller, TX
    So I am in the process of installing heated Recaro Sportsters in my R60. The stock harness for the heated seats had 4 wires, two thicker wires, brown and red and two thinner wires blue and green.
    The harness on the Recaro has a brown and red wire.
    Any idea if the brown and red wires go together? Curious what the other wires from the stock harness were for. Any help would be appreciated.
  2. Metalman
    I'm going to suggest the two thicker wires are the ones carrying the amps for the seat heaters..... The two thinner wires might be for the airbag seat occupancy light....
  3. Dave.0
    Heated seats in Texas???
  4. BlimeyCabrio
    You really want to be careful with this...
    Do you know if the two seat heaters have similar resistance values? etc.
    If it's sufficiently different, it could blow fuses, freak out your body module, etc.
    I got a heated Corbeau, and it's designed to connect to it's own control unit. No way it would work with the factory seat heater controls without some modification.
  5. Dave.0
    Yes be very careful because the a$$ you could burn may be your own. :rolleyes:
    Oh and as Paul (Blimey) said the BCM.
  6. Angib
    I believe the JCW Recaro seats are just the regular Sportster seat but with wiring and subframe customised to the R56. In order to use them the car has to be coded to accept not having an occupancy sensor in the passenger seat. So once these are installed, your R60 will need to be coded for this - and there's no guarantee that is possible. For example, Coupés and Roadsters cannot be coded to ignore the passenger seat occupancy sensor becasue the JCW Recaro seats have never been an extra for these cars. I don't know which way the R60 goes on this.
  7. Dave.0
    #7 Dave.0, Mar 17, 2015
    Oh yes they can but you have to trick the system with resistors to make the system think the OC3 mat is in the system. :ihih:
    Just go to ebay and search for Mini Cooper Seat Occupancy Mat Sensor Airbag Emulator.
    I have one on my NON MINI seats and it works great. I have OEM Mitsubishi EVO IX Recaro's in my MINI.
  8. wzabrouski
    32
    Executive Director
    Keller, TX
    The air bag sensor is a different set of wires. I am currently using a resistor to make the car think I still have the airbags. I have not had luck with the emulator I purchased. I have another Recaro coming for the pass side so I need to figure out why to do with the occupancy sensor. Might roll up and zip tie under the seat.
  9. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    ...and a factory airbag.
  10. Dave.0
    Blah... Airbags :incazzato:
    Modern cars have too many Airbags.
    People think "I have ABS, Auto Braking, Auto parking and 15 airbags I can drive like an idiot, talk on the phone, read a book behind the wheel and if I get in an accident I will survive and just get another car."
  11. Eric@Helix
    1,257
    Shepherd
    Philadelphia
    Lol. True Dat. But back on topic:
    Hrrrng
