Interior 2nd Gen Installing seats
Discussion in 'Tuning and Performance' started by btwdriver, Jun 1, 2009.
  1. btwdriver
    btwdriver New Member
    I have a set of Sparco Evo 2 Plus seats with the Brey Krause brackets that I am about to install in my Mini. I have looked at tons of threads about how to disable the airbag light with a resistor, usually around 3ohms or so. But when I put a meter on my airbag (and by the way all the connections are in one big plug now, not multiple like they used to be) it reads zero resistance.
    Has anyone else gone through this?
    It seems like I will also have to remove the passenger seat sensor and install it into the new seat. That appears to be the only way to make the remaining passenger airbags work. I also read somewhere that the passenger seat sensor is coded to the vehicle which necessitates tearing the old one out of the seat, instead of purchasing a new one.
    While I am on a roll, there are also seat position sensors which trigger one of two discharge mechanisms for the front airbag, based on how close you are sitting to the wheel/dash.
    If anyone has dealt with any of these issues, I would really appreciate a short cut.
  2. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #2 Nitrominis, Jun 1, 2009
  3. PGT
    PGT Wheel Whore
    Federal Gov Contracting
    Leesburg VA
    wrong, you read it on the seat side of the plug - you need to know what resistance the seat shows the system to fool it with a resistor.
    As for the other issues, I got a donor seat from a junkyard - you have to cut the OC3 mat out. The position sensors are another thing entirely...probably have to do with the sliders.
  4. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #4 Nitrominis, Jun 1, 2009
  5. PGT
    PGT Wheel Whore
    Leesburg VA
    I measured mine at the seat. :dunno:
  6. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #6 Nitrominis, Jun 1, 2009
  7. drPhilGandini
    drPhilGandini MINI of the Month May 2009
    Well, I have Sparco Evo IIs installed in my car, with working passenger seat weight sensor and no lights ever. I used Brey Krause sliders and a 4ohm resistor. I cut the weight sensor out of my OEM seat and installed it (it fits very well) in the Sparco.
    Just my experience.
    Also, I can't explain Nitro's observations, but they don't make any sense, electrically. If you insert an ohm meter in series in a circuit, you are measuring the resistance of the circuit. Measuring across the open car plug tells you how much resistance there is in that circuit, measuring across the open seat plug the same idea. I don't know of any ohm meter that can measure the resistance that a circuit *expects* to see across an open plug...
  8. PGT
    PGT Wheel Whore
    Leesburg VA
    for what I did, I was measured the passive load of the airbag system so that I could replicate it with a resistor. I'm not sure how measuring the wiring and control system could tell you anything about the part you removed (the seat).
    Perhaps you had it on the wrong setting? I can't see well from the pic but I don't see the Ω symbol which is resistance.
  9. btwdriver
    Some of those cars look like R53's.... My car is an R56. The pictures that I have seen of the R53's, they have 3 separate plugs. The R56 has one single large connector (maybe 3 inches wide), inside it are three separate plugs. One of them being the airbag, when I measure resistance across that I get a nominal resistance of 0.3 ohms... basically no resistance. I have checked my meter against some resistors that I have, so I know that part is working.
  10. drPhilGandini
    BTW, btwdriver, I realize your car is an R56, but I doubt Mini did anything but merge the 3 connectors into one for the passenger seat. (Does the driver's seat just have 2 connectors merged--there's no weight sensor, so it should only be the 2?)
    Anyway, my guess is you won't have problems with 4 ohms. I did use high wattage resistors, of the kind used in speaker crossovers--they handle a lot of load and give you great headroom. I've never had any problems at all with my set up since the day I installed it, over a year ago.
    You can see them in my Featured Mini here on Motoring Alliance.
  11. btwdriver
    What did you do about the stock seat belt mount? The Brey Krause mounts that I have don't have any, I was just going to drill a hole in it for the bolt. The metal is pretty beefy and should be sufficiently strong. I was thinking that a small bolt might be fine for the forward hole on the stock belt mount, the one that holds the mount level.
  12. btwdriver
    I will check again, but I definitely measured 0 ohms in both seats. Both the drivers seat and the passenger seat have 3 connectors.
    1. Airbag
    2. The connectors that go to the seat belt sensor and the pretensioner
    3. Drivers side: The seat heater and the seat position sensor
    Passenger side: The seat heater and the OC3 mat.
    Also, what do you consider high wattage resistor? 1/2 watt?
    Thanks!
  13. SK8BRD
    SK8BRD New Member
    btwdriver,
    This is right up my ally. And it's too confusing to do over the web. Let's get together and figure out what the right setup should be.
    Mike
  14. Nathan
    And then write up a nice article for the library on how to do the seat swat thing!!
    Please...
  15. btwdriver
    I'm afraid that it just might be an article about what not to do... in any case I will definitely put something together. I have found that R56 information is very hard to find. I even talked with our favorite local dealer and they didn't have much insight on doing this.
  16. btwdriver
    I will definitely take you up on this. I will PM you my cell.
  17. SK8BRD
    SK8BRD New Member
    I'm not going to let 7 years of Electrical Engineer schooling go to waste!
    We'll get connector numbers and pinouts and post.
  18. drPhilGandini
    I'll hand it over to SkateBoard (as surely that's what his handle stands for?) as he's got about 8 years more EE than me! Good luck.
  19. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    #19 Nitrominis, Jun 1, 2009
  20. Ryephile
    Ryephile New Member
    Apr 9, 2009
    299
    122
    Yes!
    Metro Detroit
    If you're getting zero ohms for your seat pyro, its because you don't have the harness plugged in. The connector has a bridge that shorts the seat 'bags when the harness is unplugged.
    I'm going through the same thing right now on my '02 R53 [installing seats]. I know your car is an R56, but apart from the seat e-field occupant detectors the rest should be applicable [apart from wire colors most likely] Here is a rundown on what you'll need to do to satisfy the airbag module and keep the front bags active:
    *Head curtain load = 2 ohms
    *Battery pyro = 2 ohms
    *Side impact sensors = 79 ohms
    *Thorax bags = 2 ohms
    *Seatbelt Pretensioners = 2 ohms
    *Seatbelt buckle indicator = you need a voltage source [I built a divider out of 390kOhm and 39kOhm resistors using the purple wire as the 5V source] presenting 450mV to the Blue/Yellow signal wire.
    The power rating of the resistors isn't important. If you get in an accident the resistors most likely won't be powerful enough to resist becoming fuses, which is ok because they would've presented their load for that one critical use.
    I hope this helps!
    Ryan
