2nd Gen R56 Cooper S Intercooler Cleaning
Discussion in '2nd Generation: 2007+ R55 through R61' started by Qik, Feb 12, 2016.
  1. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Has anyone done this? From what I've found, folks have used acetone on their intercoolers. Nobody says how much or what to rinse with etc. Do I fill it up completely with acetone? Ideas?
    I clean mine in the spring. I seal off one end really well with plastic and hold it in place with rubber bands and some duct tape.
    Next I turn it on its end and pour in a 2-3 cups ( I don't measure ) of acetone or spray a whole can of good brake cleaner in it, cover the other end and shake the hell out of it and pour out. You can rise it with water if you want but everything is going to dry so it does not matter.
    Then I unseal the other end, blow air in it with an air gun or leaf blower and sit it in the sun to dry.
    Its that simple.
  3. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Thanks Dave.0!
  4. TWISTER
    TWISTER Active Member
    53
    Web Developer/Designer
    Piedmont Triad, NC
    I saw a guy fill his up with soap and water once. I thought he was crazy/stupid!
  5. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    I don't know about crazy or stupid, but there are better ways...
  6. ZippyNH
    always struck me as a "feel good" procedure...its not gonna do much good as the pvc condensate will coat it again in seconds...but a once a year cleaning when you check the boots (on a gen1) or clamps and connectors (gen2)..not gonna hurt if done right....but not help much...
    one tip...if an excessive amount of oil is found in the inter-cooler in a gen2, then the seals in the turbo are failing....on a gen1...not so much of an issue....
  7. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    I pulled the little hose off that goes from the valve cover to just before the turbo and oil was dripping out of it. SO, following an oil catch can, the intercooler will be cleaned. I think it's more than just a "feel good" procedure. If the oil fairly heavy before the turbo, it's gotta be fairly heavy inside the intercooler. I think a lil cleanse will help efficiency somewhat.
  8. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    I soaked mine for several days in a Simple Green solution, rinsed real well, done. will do it again this spring when I change the SC oil again. Normal annual maintenance for me.
  9. Metalman
    There are also sensors in the pressurized track that can get gummed up with oil and can mess with the readings going to the ECU... A clean track is a healthy track...:Thumbsup:
  10. Lorenzo
    Lorenzo New Member
    Music City
    "A clean track is a healthy track." I do believe the FruitCake Lady espoused that same message several years ago on Jay Leno. [ame="http://youtu.be/zLLDkY5hcxw"]Miss Puss - YouTube[/ame]
  11. mrntd
    I use Dave's method only with starting fluid.
  12. Rainman768
    Rainman768 Active Member
    May 3, 2012
    167
    81
    Would the pressure sensor on the intake manifold be one of them? We had to have the clubby's replaced last fall due to a bogus 2C57 fault code.
  13. Grizld700
    Grizld700 Well-Known Member
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Oh yeah, I plan on switching mine out this year, b/c I looked at my MAP sensor and it was horrible on the inside.
  14. Metalman
    #14 Metalman, Feb 15, 2016
    Yup
    Part #5
  15. Grizld700
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    That one too. The one that was really bad on mine was on the actual intake manifold that bolts up to the head.
  16. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Denatured alcohol displaces and absorbs water. Even though I don't have enough miles to warrant cleaning, when I do...
    I will first use Dave O's method of using Acetone (a great solvent).
    Next a rinse with a 10% solution of Simple green.
    Next, a bath in denatured alcohol to remove any residue and water.
    It's just my plan...what do you think?
  17. Rainman768
    May 3, 2012
    167
    81
    We had replaced the one that metalman pointed out and the one on the manifold. Unfortunately a check engine light came on yesterday. I hope it's not the same code. I really need to invest in a good reader...
  18. Grizld700
    Feb 2, 2016
    1,212
    47
    Eastern Iowa
    Keep us posted!
  19. gregsmini
    gregsmini New Member
    Apr 10, 2010
    Harleysville, PA
    I have 113,000 miles on my 2008 S and this seems like a good idea. But....I don't hear anybody saying what they've found when they clean the intercooler. Does anybody find quite a bit of oil, only a little? I have an oil catch can which I get quite a bit of condensate but virtually no oil. I guess I'll have to check it out when the weather warms up. Thanks for the comments!
