Interior cleaners.
Discussion in 'Detailing' started by M1N1, Mar 30, 2014.
  1. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    As the temp in NW Ohio reached 54f, I decided to start the process of cleaning the M1N1. Chili Red looks soooooooo good with a shine:drool Not a full wax as yet, but still looks great with no salt on the sides!
    Can anyone recommend a good interior cleaner for the dash, doors, etc.? I have the anthracite interior. Also, I need a shampoo for the carpets. Because ODOT salts the living carp out of the roads, I have salt residue dried onto the pedals, and carpet.
    6,303
    Can't help on the cleaner, sorry. But your correct nothin looks better than a chili red MINI when it's clean!
  3. Dave.0
    I use home carpet soap 50/50 mix with warm water in a spray bottle with a brush and a wet dry vac. It works very well without soaking the hell out of your carpets.
    As for the plastic parts I use the same solution to clean off dirt and dry it with a towel and dress with Prima Nero.
  4. Z06_Pilot
    Z06_Pilot Well-Known Member
    331
    263
    Network Design Engineer
    I like Formula 303 on interior plastics and vinyl.
    10,055
    I'm a Nero user too. I've heard good things about 303. Either will do a fine job for you.
  6. ZippyNH
    I have always had good luck with washing the mats, and vacuming the heck out of the carpets...a bit of carpet cleaner...and a wet/dry shop vac to extract for the hard to clean gunk...
    I know a detailer who swears that a steamer (liker they sell on TV to clean around the house with a wand) is the best thing for all interior stuff...no chemicals...and can be vacuumed up/out with a good wet/dry shop vac.... saw him make a car look like new...the ground in crap in the interior sidewalls looked new...and the seats had a couple gallons of gray water that was sucked out by the time he was done....one hand to steam...the other to suck....alternating....
  7. Dave.0
    An easy way to clean carpet floor maps is take them out and spray them down and scrub them and rinse.
    If you want to get crazy clean take them to your shower and scrub them in your tub with Hot water and rinse them with a removable shower head holding them against the tile wall.
    10,055
    I've hung them up in the spray it yourself car warsh & let them have it. You'll be amazed at the amount of carp that come out of carpeted mats. My MINI has the all weather rubber mats so they are very easy to clean.
  9. Dave.0
    Yeah I use my 2600 PSI pressure washer and hang them out in the Sun to dry.
    Mine never get that dirty but when I detail others cars that's a different story. :(:arf:
