1st Gen R53 Cooper S Intermittent P1689 code?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by BlimeyCabrio, Jan 10, 2013.
  1. BlimeyCabrio
    In the past several weeks, I've thrown this code three times. Once the car went into limp when i mashed the throttle when a stop light turned green, the other times I've had no symptoms other than the code and SES light. If I clear it, the car may drive fine with no codes for a week or two (many hundreds of miles) before throwing the code again.
    I don't know if cold weather has brought it on, or if that's just coincidental.
    I know it's a throttle code, I've searched and read all I could find, but I've never read about what anyone did to resolve it - folks will post that they have the code, folks will post a few suggestions, then there's never a follow-up on recurrence or resolution.
    Trying to decide if my throttle body is going, or not. I have a spare (I think). I may throw it and the necessary tools in the car, just in case....
    Anybody have any experience with this?
  2. Jason Montague
    :cornut: No help here. I can't even find that specific code (P1689) in our library under 1st gen MINIs and I believe that yours is an R52 S. I have an R56 so I guess that we'll have to wait for some R53 or R52 S type people to come along. Good Luck.
  3. Dave.0
    Here's the definition of DTC P1689 -
    P1689 5769 Electronic Throttle Control Monitor Level 2/3 Torque Calculation Error.
    If you have access to a BavTech tool have your car scanned and reset all the adaptives.
    Enthusiast kit - option 1...$287.00
    http://www.bavariantechnic.com/buy.aspx
  4. minsanity
    minsanity Well-Known Member
    Sep 11, 2009
    581
    352
  5. Dave.0
    Yup is just a Throttle Control Calculation Error that can fixed with the BavTech tool by resetting the adaptives.
    Its a very easy tool to use and it cheap at only $287. I have one and use it all the time to help people out. It pulls all MINI / BMW codes and allows you to reset things like adaptives and airbag lights. It has a lot of features that autozone type scan tools cannot provide.
    Also the 3 VIN limit is not an issue if you do not register VINs in the tool.
    It will also clear the dreaded P2096. <-- read up on that one.
  6. Nathan
    Recently had the same code and limp mode. Cleared the code and went on with life, no more problem.
    Mine triggered on a very cold morning, below 20F, car was warmed up. I did a bunch of downshifts with throttle blips coming to a traffic light on a long highway off ramp. Recently had changed tires from summer to winter as well.
    Not sure if that helps at all.
  7. minsanity
    Sep 11, 2009
    581
    352
    Temp could be a factor. Dave's BavTech tool approach seems like a good investment. Does it cover the current Bimmer models, Dave?
  8. BlimeyCabrio
    I have AutoEnginuity and can clear adaptations with that. Will give that a try.
    Thanks for all the thoughts.
    P
  9. Dave.0
    Yup :Thumbsup:
  10. minsanity
    Sep 11, 2009
    581
    352
    Thanks, Dave. Any updates, Paul?
  11. BlimeyCabrio
    Waiting for it to get cold again here before I reset adaptations.. Almost 80 today, will be back in the 40's on Tuesday
