Way Motor Works is excited to have the new Scangauge E available for MINI owners. The ScanGaugeE features more then 18 built-in digital gauges that can be displayed TWO at a time along with the real-time fuel efficiency feedback graph. The Scangauge II has 4 gauges available at a time, this is the biggest difference in the two scangauges. The other big difference in the two is the Scangauge E has the graph on the screen. Gauges include coolant temp, MPH, MPG, ignition timing, throttle position, MAP pressure, open or closed loop, Engine Load, Fuel pressure, intake air temp, average fuel economy, battery voltage, days fuel cost, C02 output. Basically its a little smaller than the Scangauge II, only displays 2 gauges, and is cheaper at only $99
