1st Gen R50 Cooper Is there a way to up the idle from 750RPM?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by RallyMini370, Jul 22, 2013.
  1. RallyMini370
    750rpm is a bit low for my aggressive clutch so I stall the engine many times, is there a way to up the idle to around 1000rpm? I did think to put a set screw on the gas pedal to hold it down a little.
    Most of the tunes available will be able to adjust the idle speed. Not sure how to do it without getting into the ECU otherwise.
  3. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    IS there not a way to adjust the throttle cable a little? Thats the oldschool way to do it.
  4. minime331
    minime331 New Member
    Jan 27, 2012
    145
    30
    washington dc metro area
    The throttle is electronic
  5. Metalman
    Software change to the ECU...
  6. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Damn, thats right. These newfangled cars all use drive by wire.
  7. Metalman
    ^^^ Yes, there is not a way....
    Maybe if you short the wire it will tighten things up. ;)
  9. beaner
    beaner New Member
    44
    "Mynes" set at 1250 in the race car.
  10. RallyMini370
    hahahahaha you guys kill me...shorten the wire! There's no way I'm sending off the ECU again....I'll fiddle with a throttle stop or wear lead boots!
  11. beaner
    beaner New Member
    44
    drive faster, ignore stop signs, never stop on an incline, etc. nothing wrong with your idle. work on technique. should work fine in CR.
