2nd Gen Coupe Is this a MINI part??
Discussion in '2nd Generation: 2007+ R55 through R61' started by friendraja, Aug 7, 2016.
  1. friendraja
    friendraja Member
    Aug 31, 2015
    System Administrator
    Dublin, ohio
    Guys,
    Any idea about the below part??
    Did a autox and the corner staff handed over this part, saying it was from my Mini coupe..
    Thanks
  2. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    It looks like there is a part number stamped on the top of it. Plug that into Google and see what it returns...never seen anything like that though...
  3. Metalman
    can't make out the numbers... what are they?
  4. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    I can't tell either, but looking at the spacing it may be a BMW Part Number.
  5. friendraja
    friendraja Member
    Aug 31, 2015
    Dublin, ohio
    31 33 2 283 805 01....4 >pp
    Sent from my SAMSUNG-SM-N920A using Tapatalk
  6. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    According to RealOEM it is a 15mm suspension block. Part 31332283805
  7. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Almost looks like something that may have been used for shipping and supposed to be removed?
  8. friendraja
    friendraja Member
    Aug 31, 2015
    Dublin, ohio
    What does that mean?? Mine is a 2012 stock jcw coupe...
    realoem says part ended in 2008..
    Does that mean, this one belongs to other car??
  9. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    I would contact your local dealer, as there isn't much info online about that part. I have done several suspension installs on R53 and R56s and never seen that part before. I am guessing, but it may be some sort of spacer that is placed in the springs when shipping the car here to the U.S. to limit suspension travel or damage? Again I am just guessing on that...
  10. friendraja
    friendraja Member
    Aug 31, 2015
    Dublin, ohio
    Sure..will definitely contact the local dealer, MAG in dublin
    Thanks Guys for the info
  11. Metalman
    Jack up your MINI and lift the dust boot for each damper...
    MINI puts shipping spacers in the suspension for the boat trip across the pond to reduce suspension travel...
    They are supposed to be removed once delivered to the customer...
    There should be two white spacers and one blue spacer that gets removed...
    Sounds like someone didn't get them all removed...
    Should be a simple process for you to do if you don't want the hassle of taking it back to the dealer...
    [ame="https://www.youtube.com/watch?v=nzY2QLaoXrc"]https://www.youtube.com/watch?v=nzY2QLaoXrc[/ame]
  12. friendraja
    friendraja Member
    Aug 31, 2015
    Dublin, ohio
    Ahhhh...thats so nice explanation...its defnitely going to solve the problem
  13. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    I'm surprised they weren't making an awful noise!
  14. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    I bet the car will feel a lot better with them removed!
  15. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    If the OP bought the car new, I would take it to the selling dealer and rub their noses in it just a little. :devil:
    CD
  16. B.A.D.
    See Raj, I knew you would get a quick answer here. Maybe that's why your times started dropping!
  17. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Do you reckon having the suspension fully functioning as it was engineered to function might help lap times? :biggrin5:
    Hoping for a good outcome. :fingerscrossed:
    CD
  18. Metalman
    Or..... Just do some more autox and flip the other ones out...
  19. DneprDave
    It's my night retainer! Where'd you find it? :eek:
  20. friendraja
    friendraja Member
    Aug 31, 2015
    Dublin, ohio
    Yea...maybe that's the reason..nd the response on MA is very quick...
    Yes..i bought this car new, in 2014..it was 2012 model, sleeping in the showroom for 2 years..i was using the run rocks nd the suspension is very hard.. i will check the other corners for the spacers...
