2nd Gen R56 Cooper S Is this caused by Sticky Caliper?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Worldlygent, Aug 3, 2013.
  1. Worldlygent
    Worldlygent New Member
    Aug 18, 2010
    #1 Worldlygent, Aug 3, 2013
    My rear (esp. Left Side) brake makes noise as if it's dragging, especially noticeable at 15 mph with clutch depressed (less engine noise). The inside rotor is rough and wonder if its a sticky caliper and if there is an inexpensive or easy fix?? I'm using EBC Red Stuff pads and EBC slotted rotors. See Photo.
    I wonder if the whole inside pad is still attached to backing plate?
  3. ScottinBend
    It also might have simply come off of the clips on the piston, but that wear pattern is definitely something you want to check out.
  4. CHKMINI
    It looks like part of the pad is missing....indeed it demands immediate attention. Keep us updated!
    We didn't have time, etc, to take things apart and investigate properly. For those who can't tell, that's the hub side of a rotor still mounted to the hub...made it a bit of a challenge to get a good pic.
  6. Systemlord
    Systemlord New Member
    Mar 28, 2013
    311
    67
    It looks like only half the pad is making contact with the inner rotor surface, I bet you lost half you pad from the looks of it! Don't wait have it checked out, nows the time to investigate! That rubbing sound could be a small piece of the pad broken up scraping the rotor.
