Engine Drivetrain 2nd Gen S I've Been Doing This Lately....
Discussion in 'Tuning and Performance' started by Metalman, Jun 13, 2012.
  1. Metalman
    OK, I do like shifting my manual MINI (No ruckus needs to be started here about the manliness of DIY shifting)....:crazy:
    But lately in town I've been using the top three gears in the shift pattern, namely 1 - 3 - 5. It seems much less tiresome for in town motoring. RPM matching seems almost perfect and I'm sure I'm getting better gas mileage versus rowing through the gears to 5th.
    Try it... You might like it.....:D
    PS: I'm fine with my manual.... Sometimes I like Mr Jekyll and sometimes I like Mr Hyde.:Thumbsup:
    I often skip gears while toddling around town. Our cars have torque, I say why not use it. :D
    Years ago I read an interview with Prost & he explained how he often skipped gears. I figured if it was good enough for the world champion it was good enough for me. :smile5:
  3. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    Yup, that's how I maintain high average gas mileage. If the traffic and road conditions are right it's 1,2,5, short on the 1 just to get it rolling.
  4. CHKMINI
    FOR ME IT IS 1..2..4..6
    1, 2, 4, 6 here when getting on the freeway.
  6. Justa Jim
    I'm going to give this a try, but I think I might need all of mine. I'll report back later.
  7. BThayer23
    I have to shift my other car 1-2-4 in the morning because the third gear synchro is too worn to work when the transmission's cold. :biggrin5:
    It's harder to short shift the R53 because it sounds so good when you get on - off - on boost.
  8. agranger
    1,486
    Yep. Same here.
  9. Little Wing
    Little Wing New Member
    Sep 7, 2009
    340
    72
    Tallahassee, FL
    I thought you had to go 1-2-3-4-5-6! :eek:
    This saves on gas?
    It doesn't hurt the transmission?
    Love this forum.
    Thanks to all posters.
    I have learned so much about my car that I would never have known otherwise. :Thumbsup:
  10. Zapski
    In stop and start I just use 2, maybe 3. But 5 almost never gets used for me.
    So count me in the 1,2,3,4,6 crowd most of the time.
  11. Metalman
    Operator error is what hurts transmissions.
    As long as you don't "lug" the engine, the sooner you can get into the higher gears your gas mileage gets better. Keep in mind, for every rotation of the engine crank, you roll farther in the higher gears......:D
  12. Minidave
    4,595
    I used to use the 1.3.5 pattern all the time in my '03 since 1st was so tall in that car....
  13. Little Wing
    Sep 7, 2009
    340
    72
    Tallahassee, FL
    #13 Little Wing, Jun 13, 2012
    Thanks for the reply MM!
    I'm just really careful and have a couple of non-negotiable rules:
    1. Teenagers don't learn to drive shift on my MINI.
    2. Teenagers don't drive my MINI even if they learned to drive shift elsewhere, hoping to get to drive my MINI.
    3. Teenagers can get a job and buy their own MINI.
    I knew about higher gear meaning better gas mileage.
    I didn't know that I could skip over a gear.
    Except, I don't use first if the car is already rolling in neutral.
    What is "lugging" the engine? :confused5:
  14. Jabbles
    Jabbles New Member
    24
    HVAC service
    Sarnia, Ontario, Canada
    I only occasionally skip gears. Just habit to got through in order.
    As far as lugging, if you shift in too high a gear too soon. Hard to explain the exact feeling but basically the engine will feel very week, not good and not fun.
  15. Little Wing
    Sep 7, 2009
    340
    72
    Tallahassee, FL
    Thanks.
    I have a feel for this, just don't know how to put it into words.
    It's one of those things that you really feel in the pit of your stomach if you do it wrong! :blush2:
  16. Metalman
    What is "lugging" the engine? :confused5:[/QUOTE]
    Lugging happens when an engine's rpm is below its power curve and is struggling to give motion to the vehicle.
  17. Little Wing
    Sep 7, 2009
    340
    72
    Tallahassee, FL
  18. Nathan
    "Lugging" the engine is when you grab it by the manifold and carry or "lug" it around :D
  19. Justa Jim
    OK, gave this a try and found that it worked great while going down hill. Otherwise I need all my gears and glad to have them. :Thumbsup:
  20. Little Wing
    Sep 7, 2009
    340
    72
    Tallahassee, FL
    I thought so.
    My husband says that I really know how to put the "lug" in luggage...
