2nd Gen JCW JCW engine issues
Discussion in '2nd Generation: 2007+ R55 through R61' started by mrntd, Oct 23, 2012.
  1. mrntd
    Does the JCW have the same engine issues as the mcs? Like the timing chain and water pump
  2. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    Yep, as far as I know.
  3. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    Standard problems, sorry.
  4. RussWK
    RussWK Active Member
    Apr 1, 2011
    106
    61
    So, when do these problems happen? I know people with close to 200K on original engine and no issues. However, I do plan to service SC and WP at around 100K (maybe sooner) which is another 50K.
    So far for my car has had no issues - even after many bolt-on mods (Complete Madness performance II package).
    Any alternative advice or opinion?
    2006 R52, 46K miles.
    --Russ
    The OP was asking about the 2nd generation MINIs. Being you have a 1st generation you get a whole different set of standard issues.
  6. mrntd
    Thanks for the info. Is the timing chain issue a recall or does there have to be a problem?
    I do not believe it was a recall.
  8. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Nope no recall, but my brother had his done "goodwill" by Cincinnati Mini at 62,000 miles. I believe MAG has been pretty proactive about it also. But depends on the dealer, as we all know some are better than others...
  9. CHKMINI
    Nick, is the car in the Columbus area? If so have Sam at MAG run the key and you will get the service and repair history.
  10. mrntd
    One I am looking at is in cincy. The other is in Salt Lake. I'll get the vins and have them checked. Thanks
  11. HiFi Guy
    HiFi Guy New Member
    Jul 30, 2012
    46
    Orlando, FL
    Correct. When I had my car if for service, they found a small oil leak because the bolt had started to back out. My MA told me that originally, they thought the problem was only on 2007-2009 cars, so that is what the dealer was checking. Now they check every second generation S- they are saying the problem is widespread.
    I was told that there is no official recall, but rather it is a service campaign. Mini doesn't know which motors are affected, as the motors are sourced from Peugeot, who unfortunately can't determine which motors are affected either.
    My car was caught early at 28K miles. Only the bolt and tensioner were replaced- the chain was fine.
  12. CHKMINI
    Nick, if you PM me the VINs I'll be glad to run them by Sam and see if he can dig up the history.
  13. mrntd
    I had mini check the VINs. The one in Cincy is good to go. The one in Salt Lake is a salvage title.
  14. CHKMINI
    When's the road trip to Cincy?
    Cincy...Cincy...Cincy:beer:beer:beer
