2nd Gen R55 Clubman JCW stage 1 kit
Discussion in '2nd Generation: 2007+ R55 through R61' started by rum4, Dec 11, 2011.
  1. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    #1 rum4, Dec 11, 2011
    Anyone running this on a Clubman? Is this the way to go or is there a better way to get more power?
  2. rum4
    4,568
    1,475
    SC
    ANyone?
    What is included in the Stage 1 Kit?
  4. rum4
    4,568
    1,475
    SC
    Here is a description;
    The John Cooper Works tuning kit drives the MINI Cooper S Clubman to completely new heights of performance. The kit boosts the output of the Twin Scroll turbocharged engine to 189 hp (SAE) (141 kW). The maximum torque is 185 lb-ft between 1750 and 5000 rpm. In fact, with the over boost function, temporary peak values of as much as 200 lb-ft are possible in the range from 1750 to 4500 rpm. The kit includes for improved power output new air filter housing and new exhaust system which improves exhaust guidance flow. The combination of the new air filter and the exhaust provides sportier interior and exterior sound. For a more aggressive look, the tips of the dual exhaust are significantly larger than the stock exhaust tips. A special ECU programming provides faster throttle response, leading to an increased performance feel. John Cooper Works badging on the front grille, the boot lid and on top of the air filter are obvious signs that the car is powered by a JCW engine. John Cooper Works tuning kits are designed and developed according to the guiding philosophy that only serious tuning can satisfy the high requirements of MINI. This particularly applies in terms of endurance, effect on other components and compliance with statutory regulations.
  5. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    If it's for a 2011 it's not a bad deal. But if your Clubman is an earlier car your money can be better spent on a tune, and few other parts.
    If you want the JCW kit, we can sell em too.:Thumbsup:
  6. rum4
    4,568
    1,475
    SC
    No mine is a 2012 clubbie
  7. Rae
    Rae Club Coordinator
    Oct 14, 2010
    907
    Oregon
    J has an 08 and even with an ECU wishes that Maddie had gotten the JCW package. The stock suspension is wall-oooow-yyyyy! If you rally want to drive the car . . . Go JCW, but that's just my .02
  8. Octaneguy
    Octaneguy New Member
    Apr 24, 2009
    579
    31
    Dream job
    Anaheim, CA
    Just go aftermarket
    I went with an aftermarket intake and exhaust which improved the sound but after the tune from Way, I was chirping the tires. I would go with the JCW kit only if you must stay OEM.
    Richard
    I agree that you will get more bang for your buck with aftermarket stuff, be it tuna's or hard parts.
    One thing to consider is how those things will affect your new car warranty. With some dealers it is OK as long as the parts & installation is done well. Other dealers will try & void your warranty. My dealer has been great about that issue. Best check with yours first if the warranty is important to you.
    Going with the JCW tuna & parts should not affect your warranty at all. Decision time. :wink:
    One more thought.... Be careful of which exhaust you choose. A sweet sounding exhaust can be quite tiring on a long highway slog. I'd guess the JCW pipes would be a good compromise.
