2nd Gen R56 Cooper S Jm turbo DV explosion
Discussion in '2nd Generation: 2007+ R55 through R61' started by Guapish_Fliver, Jan 6, 2017.
  1. Guapish_Fliver
    Guapish_Fliver New Member
    May 31, 2016
    272
    Pimpin
    Da wess
    #1 Guapish_Fliver, Jan 6, 2017
    I have about 500 miles on my Jm turbo 47mm and the DV come apart real good. Arric assured me that the DV was stout enough and updated for the turbo but apparently not. It looks like there are some pieces missing but my compressor wheel looks fine. It spins ok but there may be some damage I can't see. The turbo should still be under warranty but I'm not dumb enough to put another pos plastic Jm DV in there. Not quite sure how that happened but it looks like it melted. :confused5: Jm said he's never seen that before..
    I'm thinking I have to pull my plumbing apart now to see if I can fish the fragments out of the intercooler? What DV should I get for 25 psi? Forge with the blue spring? What about the DV plus from minis mania? It's $100 cheaper than the forge.
  2. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    Two
  3. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    Three
  4. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    Four
  5. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    :cornut:
  6. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    Wheel looks fine
  7. Dave.0
    Hummm Turbo problems....:idea: Nope I don't have them. :ihih::lol:
    Sorry about your R56 turbo problems.
  8. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    I accidentally posted in first gen again lol. Can this thread be moved?
  9. Metalman
    The OEM BOV can have problems with the rubber / plastic diaphragm rupturing and doing exactly what yours did...
    I went with the GFB DV, which replaces the flexible diaphragm with aluminum and brass components. The thing I liked about this design is it uses the oem solenoid to activate the BOV. The ECU can't detect a change so no error codes are thrown.... It stays happy...
    I changed out the OEM BOV 2 years ago and I've had no issues running the unit....
    http://www.gfb.com.au/products/blow-off-and-diverter-valves/dv-plus/dv-t9352-suits-mini-citroen-and-peugeot-application-detail
  10. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    Coo that's the one I was leaning towards. Do they come with different springs?
    Moved.
  12. Guapish_Fliver
    May 31, 2016
    272
    Pimpin
    Da wess
    #12 Guapish_Fliver, Jan 6, 2017
    I was thinking that since there is only about 90% of the DV in my possession that something would have almost certainly come in contact with the compressor wheel in there.
    Is there an "easy" way to pull the compressor housing off to look at the blades without removing the turbo? I'm scared of removing and installing my downpipe/exhaust again.
  13. MCS02
    6,322
    One can always hope for a first Gen:lol::lol::lol:
  14. Metalman
    No extra springs...
    The difference between it and the OEM unit...
    [ame="https://www.youtube.com/watch?v=3EgXspDfI08"]https://www.youtube.com/watch?v=3EgXspDfI08[/ame]
  15. wjosh45
    wjosh45 Member
    Nov 20, 2016
    131
    Guapish_Fliver - Sorry that happened, I would have to think it's worth a close inspection.
    Metalman - interesting, thanks for posting. I was trying to figure exactly what the overall part is and how it worked.. good stuff.
  16. MCS02
    6,322
    This may need to go on the wife's car.
  17. Zapski
    Aaaaaand bought. I figure with 130,000+ miles on mine it's a good idea to take care of this before it's too late.
    Plus, TOY! ;)
  18. Metalman
    Congratz....
    Relatively easy to install.... Just one of the allen screws (3 hold it on) was tough to get to.... You kind of have to feel for it... Took me about 30 minutes to do.... Don't forget to add a little oil (synthetic of course) to the brass / silicone piston.
    I assume you saw this video.... If not, here it is... easy assembly...
    https://youtu.be/Z1TtkSykhYo
  19. Zapski
    Thanks!
    I'd seen GFB parts talked about on Mighty Car Mods, and had been toying with this in my head for a while now. Seeing the carnage in the OP along with your recommendation really made up my mind.
