2nd Gen R60 Countryman Key fob inoperative
Discussion in '2nd Generation: 2007+ R55 through R61' started by taki0187, Jun 24, 2015.
  1. taki0187
    taki0187 New Member
    Oct 24, 2013
    I have a 2014 countryman all of a sudden the key fobs stopped locking and unlocking the doors. It has a non removable battery that charges when it's in the ignition. Tried everything. Any one else with the same problem. Been searching it looks like the sensor is in the rear view mirror. Going back to the dealer on Saturday. Thanks in advance.
    The sensor is in the rear view mirror. If all the fobs stopped working that is where I'd look first. It may be something as simple as a loose plug.
  3. MCS02
    6,282
    Welcome to MA!
  4. joey1320
    joey1320 New Member
    Jun 24, 2015
    13
    12
    If you have a sunroof, I would imagine water got into the sensor and you have corrosion forming in the connector.
    If you want, you can grab the rearview mirror with both hands and rotate it counter-clockwise about 90 degrees. This release the mirror from the holder and you can disconnect the plug and see. Before you get to the plug, just pry the plastic side covers back, so you have better access.
    If you have a sunroof and corrosion, ask the tech to inspect drain tubes and makes sure they are not blocked by some type of debris.
    Yes, I know you have warranty but this post may help others.
    Good luck!
