1st Gen R53 Cooper S Knocking in suspension
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by jbat, Oct 15, 2013.
  1. jbat
    jbat New Member
    Jul 2, 2013
    39
    15
    I have an 05 s convertable. My front right suspension knocks when I go over bumps. I've lifted it up several times and checked every bolt, everything is tight as far as I can tell. But it is getting worse over time. Any suggestions ?
    I'd venture to say the strut top rubber has ripped and is separating from the bearing. Take a good look at them to make sure this is not the case. Also look at the strut tops for evidence of mushrooming. The 3 studs should all be pointing up from the strut top a 90 degree angle. If there is mushrooming they will point off center.
    Good strut top with no mushrooming will have studs looking like |
    Mushroomed strut top will have studs looking like / away from center.
  3. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I would also suspect the rubber strut top bushing. You can see it from the engine compartment. Look down the big hole where the shock rod comes into the engine compartment. There is a rubber mount around the shock rod. The rubber is probably ripped/torn.
  4. Dave.0
    ^^^ These are the first things I would check.
    Next Lower control arm bushings or a broken end link.
