Suspension Brakes Koni Shocks and NM Springs??
Discussion in 'Tuning and Performance' started by mrminimmel, Jan 31, 2012.
  1. mrminimmel
    mrminimmel New Member
    Dec 5, 2010
    69
    I have a set of NM springs in my 2010 JCW S and I was wondering if the 3/4" drop is too much to be able to put some Koni Shacks in for better handling on the autocross races? And if they can be switched out for the stock shocks, should front and back be done?
    Thanks'
    Pete
    Hope you don't mind, I adjusted the title to more accurately reflect the question. At least I think it does.
    When switching to shock such as a Koni from OE all 4 should be done at the same time. A mix of both a performance shock and OEM will make for some wonky handling.
  3. CHKMINI
    My 09 JCW has NM springs and KONI Yellows. I consider the combination outstanding.
  4. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    The Koni Yellows are a great combo to put the the NM springs, and if you want more performance you can adjust them stiffer.
  5. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    I have that combo and I love it!
  6. mrminimmel
    Dec 5, 2010
    69
    what to adjust Koni yellows to
    I'm excited to add the Koni Yellows to the car. I have a 19mm rear sway bar set at the medium set of holes. If I move to the stiffer set of holes what setting should I start the shocks? And is an alignment necessary after the shocks go in?
    Thanks
  7. CHKMINI
    For daily driving I personally set the shocks to the softest setting. IMO you should always align the car after changing anything suspension related.
  8. minimark
    Swift springs for the win!
  9. Metalman
    Can Swift springs be matched with Koni yellows for 2nd Gen yet?
  10. minimark
    Checking.
  11. minimark
    Yes the Swift Springs are available for the second generation Minis in the OEM size!!
  12. Metalman
    Thanks....
    I'm still in class...
    When I get home I'll need to check it out....:D
  13. Jason Montague
    :cornut: Are you still repeating the 4th grade?:lol::lol::lol::lol::lol::lol:
  14. minimark
    Liked my TSW springs but love the Swifts, better in every way!!!
  15. kent kanipe
    kent kanipe New Member
    Oct 21, 2010
    79
    17
    Corvallis, Oregon
    I love my TSW's so tell me some specifics about the difference Swifts make....please and thank you!
  16. minimark
    You don't ride the bump stops, corners flatter but still turns great due to the higher rate in the rear, doesnt dive on heavy braking and recovers from an event much quicker...etc... I find them better in everyway.
  17. kent kanipe
    Oct 21, 2010
    79
    17
    Corvallis, Oregon
    Thanks for that...having just run Thunderhill III I may have to look at these when I get new shocks. I must say, however, my coach commented on how flat my MINI handled with the TSW's and 19mm sway bar. Better is always good. Thanks again....
  18. minimark
    ....go back with Swift Springs and take him for a ride!:yesnod:
  19. Mr. Jim
    Mark, the ones you bought were the Spec-R?
  20. Eggburp
    Eggburp New Member
    Apr 10, 2011
    Swift only makes one lowering spring for the Mini and its the Spec R.
    Sure cuts down on the decision making process!
    Mine will get installed this SPRING!!!!
