Brakes Wheels 2nd Gen Tires Konig Daylite Wheels
Discussion in '2nd Generation: 2007+ R55 through R61' started by Justa Jim, Nov 12, 2010.
  1. Justa Jim
    Does anybody know if this wheel, in 15X6.5 et40, would fit an R56 if you used a spacer?
  2. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    Jim,
    Does it have the 4X100 bolt pattern and the correct bolt size? (can never remember if it is 14 or 11MM which can be corrected with a stud coversion kit)
    That et and rim width should be no problem (I have 42 ET on a 7.5in wheel on mine with no prob)
  3. Rally
    Rally New Member
    50
    Ohio
    I think he's more concerned with the backpad and spoke clearance on the calipers.
  4. Justa Jim
    The Rota 15X7 are said to not clear the rear arms without a spacer. I can't find out if theses are the same or not. Web site lets you ask no questions and the couple of sellers I spoke to don't know.
  5. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    maybe get a 5-10mm spacer and take to installer? If not needed return it?
  6. Rally
    Rally New Member
    50
    Ohio
    Sadly there is no real way of knowing without trying. All wheels are made differently. The backpad and inner spoke design on the Rotas could be COMPLETELY different than the Konigs. Vendors would have to sit and test them on every single model of car to know.
    That's just part of fitting wheels. Sometimes you run into issues and sometimes you don't. Luckily, if you find you need spacers, they're affordable and easy to get.
